Centralina arrivata ora mi serve solo il tempo si sistemare tutto... che faccio un paio di lavoretti insieme...
Inviato dal mio SM-G900F utilizzando Tapatalk
Ok arrivata e l'ho messa su ma ho dei problemi con le impostazioni...
ecco le istruzioni in INGLESE
Setting: Insert the key and turn switches, operating as follows:
(A) The width light setup:
AUTO -> width light -> AUTO, and you will hear twice like "Di Di" voice, setting finished.
In this setup, if the light is within the range of turning width lights, it will turn on immediately. And if the light intensity is quite high when setting, then put the width light turning to the earliest.
(B) Headlight setup:
AUTO -> HEADLIGHT -> AUTO, there will be voice like "Di Di Di" if succeed.
In this setup, if the light is within the range of turning headlights, it will turn on immediately. And if the light intensity is quite high when setting, then put the headlight turning to the earliest.
(C) The tunnel mode:
AUTO -> 0 -> AUTO
you will hear a voice like "Di" once, and you finished adjust it to more sensitive; do the same way again, you hear voice "Di Di", twice, and it adjusted to less sensitive.
(D)coming home and leaving home
Close the ignition and complete following:
AUTO--0—AUTO—0—AUTO, you will hear a sound like "Di" , width light begins to flash, close the switch to 0 after 5 more second, that is the time set for coming home and leaving home. If switch turned within 5 second, coming home and leaving home closed.
