    Manuel91
    Auto posseduta: Highline 1.6 tdi
    moto: Cagiva mito
    nome: Manuel
    da Manuel91 » martedì 26 giugno 2012, 17:24
    Ragazzi appena arrivato il cavo : ho un'errore.. qualcuno gentilmente sa dirmi a cosa riguarda ? graziee
    uesday,26,June,2012,18:12:16:37412
    VCDS Version: Release 10.6.4
    Data version: 20110418
    Chassis Type: 6N0
    Scan: 01 03 08 09 10 15 17 19 25 2E 44 55 56 0B
    VIN: WVWZZZ6RZCY526034
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (J623-CAYB) Labels: None
    Part No SW: 03L 906 023 MA HW: 03L 907 425 B
    Component: 1,6l R4 CR td H33 8849
    Revision: --H33--- Serial number:
    Coding: 00114016002400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM16TDI02103L906023MA 003004
    ROD: EV_ECM16TDI02103L906023MA.rod
    VCID: 71E3A4601139
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 210228E3416F00B8842514E582D500421300
    VCID: 87176AB88FBD
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
    Component: Climatronic H11 0711
    Revision: V0000000
    VCID: 3875594432C3
    Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
    Part No SW: 7H0 937 089 F HW: 7H0 937 089
    Component: BCM T5GP Li4 H50 0251
    Revision: BS050001 Serial number: 0465 251111033
    Coding: 24B02BBF08A10000003808916C2B0DD05A80672F60051041200000010000
    VCID: 39735C4009C9
    Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB
    Component: J386__TSG_FT 008 1611
    Coding: 18BC30
    Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD
    Component: J387__TSG_BT 008 1611
    Coding: 08BC30
    Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
    Component: E221__MFL-TAS H09 0013
    Coding: 020000
    Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Coding: 08BC32
    Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Coding: 08BC32
    2 Faults Found:
    03431 - Activation of Left Parking Light
    006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100110
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 58
    Mileage: 10744 km
    Time Indication: 0
    Date: 2008.14.07
    Time: 17:55:15
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 175
    Reset counter: 58
    Time Indication: 0
    Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
    Part No SW: 6R0 919 475 C HW: 7E0 919 475
    Component: PARKHILFE 4K H11 0013
    Revision: -------- Serial number: 47301125101051
    Coding: 108001
    ASAM Dataset: EV_VW250ParkiAssis2 S01008
    ROD: EV_VW250ParkiAssis2.rod
    VCID: 3E794F5C10E7
    1 Fault Found:
    1080083 - Rear Parking Aid Sensor(s)
    B107B 13 [008] - Mechanical Failure
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 58
    Mileage: 10744 km
    Date: 2008.14.07
    Time: 16:01:01
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag022 H09 0020
    Revision: -------- Serial number: 003GX00VHTTT
    Coding: 003232
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW25.rod
    VCID: 4A91138C5C2F
    Driver's Airbag Crash Sensor:
    Serial number: 3575HRB405V0Q3SKCHLR
    Passenger Side Airbag Crash Sensor:
    Serial number: 3585HRB40650P3TEE8LX
    Driver's Rear Airbag Crash Sensor:
    Serial number: 3515RRB405D0N4A8H0RI
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 3525RRB405D0N4A8M96C
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
    Component: KOMBI H04 0206
    Serial number: 00000008832922
    Coding: 140E01
    ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
    ROD: EV_DashBoardUDSJCIPQ25_VW25.rod
    VCID: 3A71434C0CCF
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 7H0 937 089
    Component: GW-K-CAN TP20 H50 0251
    Revision: BS050001
    Coding: 002200
    VCID: F0E521649A33
    Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
    Component: IMMO H04 0014
    Serial number:
    ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
    ROD: EV_ImmobUDSJCIPQ25_VW25.rod
    VCID: 3A71434C0CCF
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7660871406
    Coding: 010000
    VCID: 29538C00F969
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11230
    Shop #: WSC 00788
    VCID: 2F676218C78D
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 6R0 907 357 HW: 6R0 907 357
    Component: LWR-ECU H02 0070
    Revision: -------- Serial number: --------------
    Coding: 0110000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
    ROD: EV_HeadlRegulVWLWRPt_VW25.rod
    VCID: F7F71A78FF5D
    Address 56: Radio (J503) Labels: None
    Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
    Component: Radio RCD310 031 0075
    Revision: 01000001 Serial number: VWZ1Z2L3524207
    Coding: 01000400020001
    VCID: 336F6E682BA5
    Address 0B: Sec. Air Heating
    Cannot be reached
    markio1992
    Auto posseduta: Polo 6r - 9n
    moto: Beverly 300
    da markio1992 » martedì 26 giugno 2012, 17:40
    Io ho messo a "1" ma mi piacerebbe un pochino piu duretto, perché in autostrada il volante leggero oltre che essere scomodo è pure pericoloso, e di autostrada ne faccio tanta...cosa devo mettere? Provo con il 2? Ma io avevo il 2 di serie mi sembra..si puo mettere lo 0?
    Love is... Immagine
    lucamatrix
    nome: lucamatrix
    da lucamatrix » martedì 26 giugno 2012, 21:51
    markio1992 ha scritto:Io ho messo a "1" ma mi piacerebbe un pochino piu duretto, perché in autostrada il volante leggero oltre che essere scomodo è pure pericoloso, e di autostrada ne faccio tanta...cosa devo mettere? Provo con il 2? Ma io avevo il 2 di serie mi sembra..si puo mettere lo 0?
    Probabilmente di serie avevi il 3 (come me)... oppure il 5... che erano sicuramente più leggeri dell'1 e del 2...
    Prova il valore 2 a questo punto... e di come ti trovi!
    Immagine Immagine Immagine
    Andrea 6r
    da Andrea 6r » martedì 26 giugno 2012, 22:41
    secondo me prova il due
    manuel scrivi [urlesterno=http://www.polovw.it/foro/viewtopic.php?f=34&t=4266]qui[/urlesterno] :023
  • Friarie1992
    Auto posseduta: golf 2 e 4 serie
    nome: Antonio
    da Friarie1992 » mercoledì 27 giugno 2012, 14:40
    ragazzi sapete aiutarmi questa e l'auto-scan della mia macchina non funzionano i comandi al volante
    VCDS Version: Release 10.6.4 (x64)
    Thursday,21,June,2012,16:41:46:10074
    Chassis Type: 6N0
    Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56
    VIN: WVWZZZ6RZCY081296
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    VCID: 71EDD1F71139
    Revision: --------
    Coding: 210228E3417500B3842714EB82D700421300
    VCID: 87191F2F8FBD
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 158
    Mileage: 8577 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 16:28:24
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x12FD
    Hex Value: 0x259C
    Hex Value: 0x007F
    Hex Value: 0x7F7F
    Hex Value: 0x7BF9
    Revision: V0000000
    VCID: 387B2CD332C3
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0251
    Revision: BF046001 Serial number: 0434 239111139
    Coding: 3DB02BBF08A1000000380E006D6B0CD80088412F60860000200000000000
    VCID: 458555277531
    Coding: 18BC30
    Coding: 08BC30
    Coding: 020000
    Coding: 08BC32
    Coding: 08BC32
    1 Fault Found:
    00967 - Left Turn Signals
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 8623 km
    Time Indication: 0
    Date: 2008.14.22
    Time: 10:46:47
    Revision: -------- Serial number: 47301122501438
    Coding: 108001
    VCID: 3E773ACB10E7
    Revision: -------- Serial number: 003GX00V60HK
    Coding: 003232
    VCID: 4A9F661B5C2F
    Serial number: 3575HRB405R0OCUIDPAS
    Serial number: 3585HRB405R0OCUI5OJT
    Serial number: 3515RRB405B0M98EGOP2
    Serial number: 3525RRB404T0MFP6HHTX
    Serial number: 00000008534055
    Coding: 540A01
    VCID: 3A7F36DB0CCF
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0251
    Revision: BF046001
    Coding: 002200
    VCID: F0EB54F39A33
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 158
    Mileage: 8577 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 16:28:24
    Serial number:
    VCID: 3A7F36DB0CCF
    Revision: A1001003 Serial number: 7660780229
    Coding: 020000
    VCID: 295DF997F969
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
    Component: RNS-MID H60 4020
    Revision: AB001001 Serial number: VWZ6Z7L3249002
    Coding: 04000202040000200011
    Shop #: WSC 00152 264 18320
    ASAM Dataset: ------------------------- ------
    VCID: 316D11F7D1B9
    3 Faults Found:
    00876 - Treble Speaker Rear Left (R14)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8576 km
    Time Indication: 0
    00877 - Treble Speaker Rear Right (R16)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8576 km
    Time Indication: 0
    01523 - Microphone for Telephone (R38)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8577 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 16:09:31
    Coding: 11230
    Shop #: WSC 00788
    VCID: 2F69178FC78D
    1 Fault Found:
    49-10 - No Communications - Intermittent
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    VCID: 316D11F7D1B9
    3 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8576 km
    Time Indication: 0
    00877 - Unlicensed Version. Not all DTCs
    011 - will be decoded.
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8576 km
    Time Indication: 0
    01523 - Unlicensed Version. Not all DTCs
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8577 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 16:09:31
    POLO 1.6 TDI 90cv highline, Nero perla,Tech & Sound Pack con rsn 510,Comfort Pack,Listello cromato vw,Marmitta cromata vw,Battitacco vw,Tappetini in gomma originali vw,Pedaliera sportiva originale vw,Luci anteriori ultra white ,Luce posizione a led,Luce targa a led,Poggiapiede golf VI,Moquette cassetti,luci interne a led.
    Modifiche via vag:blocco portiere a 15 km/h & sblocco all'estrazione della chiave,consumi in km/l,Disattivazione luci diurne
    Immagine ImmagineImmagine
    lucamatrix
    nome: lucamatrix
    da lucamatrix » mercoledì 27 giugno 2012, 15:11
    Qulacuno può darmi delucidazioni in merito agli errori del mio Autoscan:
    Codice: Seleziona tutto
    Wednesday,27,June,2012,16:33:29:37412
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 6N0
    Scan: 01 03 08 09 15 17 19 25 2E 44 55 56 0B
    VIN: WVWZZZ6RZCY******
    09-Cent. Elect. -- Status: OK 0000
       Coding: 00114016000400080000
       VCID: 71E3A460A0B23B1
    Address 03: ABS Brakes (J104)       Labels: 6J0-907-37x-ESP.clb
       Revision: --------
       Coding: 210228E3417500B3842E14EA82D800421300
       VCID: 87176AB83236951
       Revision: V0000000
       VCID: 387559448B48AA9
       Revision: BS050001    Serial number: 0465 223110698
       Coding: 3CB02BBF08A10000003808916C2B0DD05A00672F60051041200000010000
       Shop #: WSC 12469 483 00190
       VCID: 39735C40B042B31
       Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
       Coding: 08BC30
       Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
       Coding: 020000
       Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
       Coding: 08BC32
       Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
       Coding: 08BC32
       Revision: --------    Serial number: 003GX00V5ECS
       Coding: 003232
       VCID: 4A91138CEDA4289
       Crash sensor for side airbag; driver side:
       Serial number: 3575HRB405T0Q3SKDGQU
       Crash sensor for side airbag; passenger side:
       Serial number: 3585HRB405V0Q3SKB8FC
       Crash sensor for side airbag; rear driver side:
       Serial number: 3515RRB40510MFP670B3
       Crash sensor for side airbag; rear passenger side:
       Serial number: 3525RRB404T0MFP6GHRU
    Address 17: Instruments (J285)       Labels: None
       Component: KOM
       Serial number: 00000000000000
       Coding: 140E01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
       VCID: 55ABF0F0341A771
       Coding: 002200
       VCID: F0E5216423B8B29
    1 Fault Found
    00470 - Combination comfort Databus in Single Wire
                012 - Electrical Fault in Circuit
                 Freeze Frame:
                        Fault Status: 01101100
                        Fault Priority: 2
                        Fault Frequency: 254
                        Reset counter: 235
                        Mileage: 4121 km
                        Time Indication: 0
                        Date: 2004.14.16
                        Time: 10:15:38
    Address 25: Immobilizer (J334)       Labels: Redir Fail!
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H03 0505
       Serial number:
       Coding: 000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_ A03009
       ROD: N/A
       VCID: EAD1330C0D64489
    No ASAM data for: "EV_" (VW25)
       Coding: 010000
       VCID: 29538C0040E2031
       Coding: 11210
       Shop #: WSC 00788
       VCID: 2F676218EA066D1
       Coding: 0110000000000000
       VCID: F7F71A784ED6E51
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Revision: 01000001    Serial number: VWZ1Z2L3509432
       VCID: 336F6E68922E491
    1 Fault Found
    00856 - Radio Antenna
                011 - Open Circuit
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 116
                        Mileage: 8656 km
                        Time Indication: 0
                        Date: 2007.14.18
                        Time: 09:03:45
    Cannot be reached
    Grazie in anticipo... :023
    Ultima modifica di lucamatrix il venerdì 29 giugno 2012, 22:07, modificato 1 volta in totale.
    steel
    nome: Stefano
    da steel » mercoledì 27 giugno 2012, 15:27
    Ragazzi avete scritto esattamente sotto al messaggio dove si dice che le per le letture vag bisogna chiedere aiuto qui: viewtopic.php?f=34&t=4266
    Qui si discute solo sulle funzioni che si possono attivare dal vag e sui problemi che si incontrano nell'attivarle, se no si ottiene solo un gran casino :023
    Manuel91
    moto: Cagiva mito
    nome: Manuel
    da Manuel91 » mercoledì 27 giugno 2012, 17:32
    Va bene ho pubblicato il mio errore su l'altra sezione.. però ho un'altro problemino.. non riesco a disattivare le luci statiche.. tutto il resto ci sono riuscito , coming velocità rcd 310 km/l ecc... ho provato sia con la versione sw 10.6.4 sia con la 10.6.5 con il cavo preso qui sul forum 11.8 mi sembra..nel byte 23 non mi vede i bit 3 e 4.. come dice nella spiegazione! ecco uno screen di quello che mi fa vedere.. ho una polo my2012 con fari bixeno di serie..
    Uploaded with ImageShack.us
    grazie mille :006
    Andrea 6r
    da Andrea 6r » mercoledì 27 giugno 2012, 18:02
    Perché tu hai la luce accanto alla lampada xeno che fa' questa funzione giusto?
    Bravo Stefano ottima osservazione ;)
    Scrivo strano perché uso il mio iPhone 4's :)
    steel
    nome: Stefano
    da steel » mercoledì 27 giugno 2012, 18:04
    Esatto, come dice andrea nelle polo con i bi-xeno le luci di svolta statiche sono quei fanali a parabola che si trovano di fianco al lenticolare :023
    Inoltre pare che alcune 2012 abbiano la centralina "codificata" per non accettare alcune modifiche successive.
    Manuel91
    moto: Cagiva mito
    nome: Manuel
    da Manuel91 » mercoledì 27 giugno 2012, 19:30
    steel ha scritto:Esatto, come dice andrea nelle polo con i bi-xeno le luci di svolta statiche sono quei fanali a parabola che si trovano di fianco al lenticolare :023
    Quindi dite che non posso disattivarle in nessun modo?:( neanche cercando qualche altro byte ? Se mi dite che è impossibile disattivarle metterò i fari a fito xeno.. Quelli posso giusto? Grazie per le Risposte ..
    Andrea 6r
    da Andrea 6r » mercoledì 27 giugno 2012, 22:08
    Non so' se ci sono possibilità per disattivarle :017
    Non ti convivere metterci un lampada xeno,una buona lampada alogena si :023
