Polo 6R --->Modulo 09 Cent Elect ai raggi X con il VCDS 11.2
    ciamardo
    nome: Principe
    da ciamardo » martedì 24 maggio 2011, 18:49
    Eccomi qui ri-posto il contenuto del File Label 6R0-937-08x-09.clb del Modulo 09 della POLO 6R estratto dall'ultima versione disponibile cioè la 11.2 (a dire il vero nel frattempo è uscita anche la 10.6.4 ma su questo Label file non ci sono state modifiche) ricordo che in questa ultima versione la 11.2 finalmente hanno aggiunto le descrizioni sul Long Code Helper quindi godetevi le novità :003
    Come leggere e capire le descrizioni del Long coding:
    LC,00,0,Selective Central Locking (Single Door Locking) active
    LC=Long Coding
    ,00,=BYTE
    ,0,=BIT
    Selective Cent.......=descrizione del bit
    Long Coding:
    LC,00,3,Auto-Unlock (Unlocking when Removing the Ignition Key)
    LC,00,4,[i]Auto-Lock (Automatic Locking above 15 km/h)
    LC,00,5,Central Locking installed -
    LC,01,7,Central Locking/Rear Lid: Rear Lid Locking/Unlocking via Central Locking -
    LC,02,0,Central Locking/Rear Lid: Soft-Touch -
    LC,02,2,Remote Control with "Terminal 15 ON" active
    LC,03,0,[i]Comfort Opening for Sun Roof active
    LC,03,1,Comfort Closing for Sun Roof active -
    LC,03,2,Comfort Function for Sun Roof active
    LC,03,3,Comfort Function for Power Windows via Lock Cylinder active [
    LC,03,4,Comfort Function for Power Windows via Drivers Interior Switch active
    LC,03,5,Comfort Function for Power Windows via Remote Control active
    LC,03,7,Comfort Function active
    LC,04,5,Central Locking Re-Locking (after 30 Seconds) active
    LC,04,6,Rain Closing active
    LC,05,0,Locking/Unlocking Optical Confirmation (Turn Signal) active
    LC,05,1,Acoustical Locking Confirmation (Horn) active
    LC,05,4,Acoustical Unlocking Confirmation (Horn) active
    LC,05,5,Comfort Closing Optical Confirmation (Turn Signal) active
    LC,05,6,Anti-Theft-System Sounder/Sirenen Port active (0 = Simple-Horn installed / 1 = Backup-Siren (LIN) installed)
    LC,05,7,Anti-Theft-System Activation Acoustical Confirmation (Horn) active
    LC,06,0,Siren Tone Type (0 = frequency modulated / 1 = discontinuoud)
    LC,06,1,Siren Alarm Type (0 = 10 Alarms (GB/Irland) / 1 = 1 Alarm (RoW))
    LC,06,2,Anti-Theft-System installed
    LC,06,3,Anti-Theft-System Deactivation via Ignition Lock active
    LC,06,5,Anti-Theft-System Delay Start (0 = with Door Opening / 1 = with Unlocking)
    LC,07,0,Central Locking/Rear: Slidung Door Left installed
    LC,07,1,Central Locking/Rear: Slidung Door Right installed
    LC,07,3,Remote Control inactive
    LC,08,0,Rain/Light Sensor (RLS) installed
    LC,08,1,Inclination Sensor for Anti-Theft System installed
    LC,08,4,Interior Monitoring for Anti-Theft System installed
    LC,08,7,Sounder/Siren for Anti-Theft System (via LIN) installed
    LC,09,3,Multi-Function-Steering-Wheel (MFSW) installed
    LC,09,4,Rear Power Windows installed
    LC,09,5,Front Power Windows installed
    LC,10,1,Leaving-Home (LH) active
    LC,10,2,Coming-Home (CH) active
    LC,11,6,Lamp Diagnostics for Back-Up Light active
    LC,11,7,Lamp Diagnostics for Lisense Plate Light active
    LC,12,0,Parking Lights ON with "Terminal 15 ON"
    LC,12,1,Daytime Running Light (DRL) adjustable (Manually AND/OR Instrument Cluster)
    LC,12,2,Interior Light after Ignition Key removal active
    LC,12,3,Emergency Flashing (Turn Signals) active
    LC,12,4,Emergency Brake Flashing (Brake Light) active
    LC,12,5,Comfort Turn Signals active
    LC,12,6,Turn/Cornering Lights installed/active
    LC,13,0,Parking Lights ON only w/o Ignition ON possible
    LC,13,1,Parking Lights Function active
    LC,13,2,Brake Lights OFF while Terminal 15 OFF
    LC,13,3,Brake Light Activation via Body Control Module (BCM)
    LC,13,5,Interior Light Enabling via Rear Lid
    LC,13,6,Coming-Home (CH) / Leaving-Home (LH) Variant (0 = Fog Lights / 1 = Low Beam)
    LC,13,7,Light Sensor Function active
    LC,14,0,Headlight Wishers installed
    LC,14,1,Rain Sensor Function active
    LC,14,2,Service Position for Front Wiper active
    LC,14,3,Comfort Function for Rear Wiper active
    LC,14,4,Tear Wiping active
    LC,14,7,Speed dependent Wiper Stage Activation active
    LC,15,0,Push-to-Talk Function via Multi-Function-Steering-Wheel (MFSW) active
    LC,15,2,Rear Window Heater Activation (via) CAN active
    LC,15,3,Mirror Heating ON while Rear Window Heater ON
    LC,15,5,Heated Front Window installed
    LC,15,6,Heated Outside Mirrors installed
    LC,15,7,Heated Rear Window installed
    LC,16,4,Lamp Diagnostics for Low Beam active
    LC,16,5,Lamp Diagnostics for Rear Fog Light(s) active
    LC,16,6,Lamp Diagnostics for (Separate) Daytime Running Lights (DRL) active
    LC,16,7,Lamp Diagnostics for High Beam active
    LC,17,3,Horn with "Terminal 15 OFF" inactive
    LC,17,4,Battery Seperating Relay active
    LC,17,7,Cruise Control System (CCS) installed
    LC,18,0~7,00,Light Setup: Standard/Parameter Settings (EEPROM)
    LC,19,4,Lamp Diagnostics for Turn Lights active
    LC,19,5,Lamp Diagnostics for Fog Lights and/or Cornering/Turn Lights active
    LC,19,6,Lamp Diagnostics for Tail Lights aktiv
    LC,19,7,Lamp Diagnostics for Brake Lights active
    LC,20,5,Energy Management active
    LC,21,2,Cornering/Turn Lights via Turn Signal active
    LC,21,5,Fog Lights inactive with High Beams active
    LC,21,7,Front Fog Lights (with Turn Lights) installed
    LC,22,5,Assistent Driving Light (ADL) active
    LC,22,6,Interlock Display (Clutch Message) in Instrument Cluster active
    LC,23,0,Alternative Voltage Supply for High Beam and Terminal 58d
    LC,23,6,Function "Daytime Running Light (DRL)" active
    LC,24,4,Transport Protocol für CAN-Databus Powertrain (0 = TP 1.6 / 1 = TP 2.0)
    LC,24,5,CAN-Powertrain "Loop" active
    Ultima modifica di ciamardo il sabato 11 gennaio 2014, 22:51, modificato 7 volte in totale.
    !!!VAGgo è sono felice!!!
    VCDS Wi-Fi HEX-NET :033
    ciamardo
    nome: Principe
    Re: Polo 6R --->Modulo 09 Cent Elet ai raggi X con il VCDS 1
    da ciamardo » martedì 24 maggio 2011, 18:50
    ADAPTION:
    A0xx= Le x sono i canali
    A000,0,Clear Learned Values
    A000,5,Clear Learned Values
    A000,6,This Channel resets/clears all learned Remote Controls.
    A001,0,Remote Control Adaptation
    A003,0,Central Locking: Auto-Lock
    A003,5,Central Locking: Auto-Lock
    A003,6,The doors will lock automatically when the
    A003,7,vehicle reaches a speed of 15 km/h or 10 mph.
    A003,8,
    A003,9,Range: 0 = OFF / 1 = ON
    A004,0,Central Locking: Auto-Unlock
    A004,5,Central Locking: Auto-Unlock
    A004,6,The doors will unlock automatically when
    A004,7,the key is removed from the ignition switch.
    A004,8,
    A004,9,Range: 0 = OFF / 1 = ON
    A006,0,Central Locking: Selective (Single) Door Locking
    A006,5,Central Locking: Selective (Single) Door Locking
    A006,6,0 = All Door Locking
    A006,7,1 = Selective (Single) Door Locking
    A007,0,Central Locking: Auto-Lock/Unlock for Rear Lid
    A007,5,Central Locking: Auto-Lock/Unlock for Rear Lid
    A007,6,Locks the Rear Lid once a Speef of 5 kph is reached.
    A007,7,
    A007,8,0 = Auto-Lock/Unlock for Rear Lid inactive
    A007,9,1 = Auto-Lock/Unlock for Rear Lid active
    A008,0,Visual Comfort Operation/Closing Confirmation
    A008,5,Visual Comfort Operation/Closing Confirmation
    A008,6,Turn Signals as Comfort Operation/Closing Confirmation.
    A008,7,
    A008,8,0 = Visual Comfort Operation Confirmation inactive
    A008,9,1 = Visual Comfort Operation Confirmation active
    A009,0,Central Locking: Audible Unlocking Confirmation
    A009,5,Central Locking: Audible Unlocking Confirmation
    A009,6,Alarm Horn as Unlocking Confirmation
    A009,7,
    A009,8,0 = Audible Unlocking Confirmation inactive
    A009,9,1 = Audible Unlocking Confirmation active
    A011,0,Central Locking: Audible Locking Confirmation
    A011,5,Central Locking: Audible Locking Confirmation
    A011,6,Alarm Horn as Locking Confirmation
    A011,7,
    A011,8,0 = Audible Locking Confirmation inactive
    A011,9,1 = Audible Locking Confirmation active
    A012,0,Central Locking: Visual Locking/Unlocking Confirmation
    A012,5,Central Locking: Visual Locking/Unlocking Confirmation
    A012,6,Turn Signals as Locking/Unlocking Confirmation.
    A012,7,
    A012,8,0 = Visual Locking/Unlocking Confirmation inactive
    A012,9,1 = Visual Locking/Unlocking Confirmation active
    A014,0,Anti-Theft: Alarm Horn (Country Setting)
    A014,5,Anti-Theft: Alarm Horn (Country Setting)
    A014,6,The Alarm Horn Country Setting alters the Type/Lenght and
    A014,7,Volume of the Alarm Tone (please obey all applicable laws).
    A014,8,
    A014,9,0 = Frequency modulated with 10 Tamper Alarms
    A014,10,1 = Frequency modulated with 1 Tamper Alarm
    A020,0,Lights: Comfort Turn Signals
    A020,5,Lights: Comfort Turn Signals
    A020,6,0 = Comfort Turn Signals inactive
    A020,7,1 = Comfort Turn Signals active
    A020,8,
    A020,9,Note: See Channel 43 for the Number of Cycles.
    A021,0,Lights: Emergency Brake/Hazard Light Flashing
    A021,5,Lights: Emergency Brake/Hazard Light Flashing
    A021,6,Flashes the Hazard Lights in case of an Emergency Braking
    A021,7,
    A021,8,0 = Emergency Brake/Hazard Light Flashing inactive
    A021,9,1 = Emergency Brake/Hazard Light Flashing active
    A022,0,Lights: Parking Lights
    A022,5,Lights: Parking Lights
    A022,6,0 = Parking Light Function inactive
    A022,7,1 = Parking Light Function active
    A023,0,Wipers: Front Wiper Service Mode/Position
    A023,5,Wipers: Front Wiper Service Mode/Position
    A023,6,0 = Front Wiper Service Mode inactive
    A023,7,1 = Front Wiper Service Mode active
    A024,0,Anti-Theft: Alarm Horn (Terminal 15)
    A024,5,Anti-Theft: Alarm Horn (Terminal 15)
    A024,6,0 = Alarm Horn with Terminal 15 inactive
    A024,7,1 = Alarm Horn with Terminal 15 active
    A026,0,Wipers: Front Wiper Tear Wiping
    A026,5,Wipers: Front Wiper Tear Wiping
    A026,6,0 = Front Wiper Tear Wiping inactive
    A026,7,1 = Front Wiper Tear Wiping active
    A027,0,Parking Light with Terminal 15
    A027,5,Lights: Parking Light with Terminal 15
    A027,6,0 = Parking Light with Terminal 15 inactive
    A027,7,1 = Parking Light with Terminal 15 enabled
    A028,0,Wipers: Rear Wiper Comfort Wiping
    A028,5,Wipers: Rear Wiper Comfort Wiping
    A028,6,Activates the Rear Wiper when engaging Reverse Gear
    A028,7,while the Front Wipers are active/running.
    A028,8,
    A028,9,0 = Rear Wiper Comfort Wiping inactive
    A028,10,1 = Rear Wiper Comfort Wiping active
    A043,0,Lights: Comfort Turn Signals (Cycles)
    A043,5,Lights: Comfort Turn Signals (Cycles)
    A043,6,Range: 1...5
    A043,7,Standard: 3
    A060,0,Anti-Theft: Interior Monitoring Sensitivity
    A060,5,Anti-Theft: Interior Monitoring Sensitivity
    A060,6,Alters the Interior Monitoring Sensitivity to prevent False Alarms.
    A060,7,
    A060,8,Range: 100...200 (50...100 %)
    A060,9,Resolution: 20 %
    A061,0,Anti-Theft: Inclination Sensor Sensitivity
    A061,5,Anti-Theft: Inclination Sensor Sensitivity
    A061,6,Alters the Inclination Sensor Sensitivity to prevent False Alarms.
    A061,7,
    A061,8,Range: 100...200 (50...100 %)
    A061,9,Resolution: 20 %
    A099,0,Factory Mode
    A099,5,Factory Mode
    A099,6,The Factory Mode is being used to visualize Errors to
    A099,7,the Workers during the Production and can once it's
    A099,8,being deactivated not be reactivated again.
    A099,9,
    A099,10,0 = Factory Mode inactive
    A099,11,1 = Factory Mode active
    ciamardo
    nome: Principe
    Re: Polo 6R --->Modulo 09 Cent Elect ai raggi X con il VCDS
    da ciamardo » mercoledì 8 giugno 2011, 21:05
    Analizzando un AUTOSCAN di una Polo 6R ho scoperto che nel Long coding ci sono ancora alcuni BIT attivi ma senza descrizione:
    Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
    Component: BCM PQ25 H+4 H46 0207
    Revision: BF046001 Serial number: 0147 351090217
    Coding: 24B029BF08A10000002000007D2B0CD00040410F60850000200000000000
    Shop #: WSC 30103 264 94494
    VCID: 3E782FF410E7
    Byte 0 ----> Bit 2
    Byte 1 ----> Bit 4 e Bit 5
    Byte 2 ----> Bit 3 e Bit 5
    Byte 4 ----> Bit 4
    Byte 15 ----> Bit 4
    Byte 17 ----> Bit 6
    Byte 19 ----> Bit 1-2-3-4
    Byte 20 ----> Bit 6
    Byte 21 ----> Bit 1
    Credo che di lavoro per quelli della ross-tech c'è ne sia ancora tanto qui sulle polo 6R :024
    Bongio
    nome: Patrizio
    da Bongio » giovedì 9 giugno 2011, 13:20
    Chissa che da qualche parte non si nascondi lo stading!!
    Gnurant
    da Gnurant » giovedì 9 giugno 2011, 13:33
    staging :sbav
    Bongio
    nome: Patrizio
    da Bongio » giovedì 9 giugno 2011, 16:00
    Gnurant ha scritto:staging :sbav
    Si insomma ci siamo capiti! :010
    Gnurant
    da Gnurant » giovedì 9 giugno 2011, 16:11
    certo, non era un post per farti le pulci sul termine! era in modalità-HomerSimpson ON :003
    come quando fa "ciambeeeeeeelle :sbav".... :005
    ciamardo
    nome: Principe
    da ciamardo » giovedì 9 giugno 2011, 16:25
    Bongio ha scritto:Chissa che da qualche parte non si nascondi lo stading!!
    la funzione "staging" la si trova nel modulo 17: Instruments peccato che in nessuna Polo è attivabile questa funzione :021
    Gnurant
    da Gnurant » giovedì 9 giugno 2011, 17:05
    ciamardo ha scritto:la funzione "staging" la si trova nel modulo 17: Instruments peccato che in nessuna Polo è attivabile questa funzione :021
    :022 peccato che non c'è la faccina che si martella le pelotas, avrei messo quella :005
    Bongio
    nome: Patrizio
    da Bongio » giovedì 9 giugno 2011, 18:49
    ma è un qualcosa che sarà nel futuro attivabile oppure non c'è speranza alcuna ?
    einstein7385
    nome: Alberto
    da einstein7385 » venerdì 10 giugno 2011, 16:27
    A meno che non ci sia quclhe novità nel modulo 17 nelle info sul long coding, NO, non è attivabile :resa
    DIFFIDATE DELLE OFFICINE
    Bongio
    nome: Patrizio
    da Bongio » venerdì 10 giugno 2011, 21:31
    Ma se non sbaglio c'è su yt un video di una 6r col tacho della gti che ha lo staging...come è possibileee ?
