Spia Avaria Motore
    filippopolo
    Auto posseduta: POLO 1.6 TDi R - BMW
    moto: Yamaha FZ1
    nome: Filippo
    Spia Avaria Motore
    da filippopolo » domenica 5 maggio 2013, 15:34
    Ciao a tutti.
    Ho escluso il funzionamento dell' EGR,e come mi aspettavo dopo una 15ina a di Km si è accesa la spia avaria motore.
    Allego sotto una letture Autoscan.
    La mia domanda:
    è possibile in qualche modo disattivare dalla centralina la lettura del suddetto parametro?
    Grazie a tutti.
    Buona Domenica
    VCDS Version: Beta 12.10.3
    Data version: 20130228
    Sunday,05,May,2013,11:43:39:55062
    Chassis Type: 6N0
    Scan: 01 02 03 08 09 10 15 17 19 25 37 44 56
    VIN: WVWZZZ........
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 MG HW: 03L 907 425 B
    Component: 1,6l R4 CR td H33 8847
    Revision: --H33--- Serial number:
    Coding: 00254016002400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM16TDI02103L906023MG 003005
    ROD: EV_ECM16TDI02103L906023LE_SK25.rod
    VCID: 77F65CB6CE1A52A6BEF
    1 Fault Found
    7337 - EGR System
    P0401 00 [175] - Insufficient Flow
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 9
    Mileage: 11452 km
    Date: 2012.14.16
    Time: 17:37:10
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 0AM-300-04x.lbl
    Part No SW: 0AM 300 053 L HW: 0AM 927 769 D
    Component: GSG DSG AG7 431 3010
    Revision: 00043014 Serial number: CU501203045541
    Coding: 0000020
    VCID: 356A96BE5F9660B66C3
    No fault code found.
    Address 03: ABS Brakes Labels: None
    VCID: 55AA363EB8D640B68C3
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
    Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
    Component: Climatronic H11 0711
    Revision: V0000000
    VCID: 38749F8A8B849DDE775
    1 Fault Found
    00457 - Control Module for Network (J519)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 4024 km
    Time Indication: 0
    Date: 2012.14.08
    Time: 09:11:27
    Address 09: Cent. Elect. (J519) Labels: Redir Fail!
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0256
    Revision: BF046001 Serial number: 0434 066120491
    Coding: 3CB02FBF28E324009A300C006CCA0DD00080410F60800041200000000000
    Shop #: WSC 34296 123 104857
    VCID: 458AE67ECC76F036FC3
    Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 008 1611
    Coding: 18BC30
    Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 008 1611
    Coding: 18BC30
    Subsystem 3 - Part No: 1K8 951 171 A
    Component: DWA-Sensor 00 001 0103
    Coding: 000000
    Subsystem 4 - Part No: 1K8 951 605 B
    Component: LIN BACKUP HO H11 9005
    Coding: 000000
    Subsystem 5 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
    Component: J245 PS72.023 H02 0007
    Coding: 081001
    Subsystem 6 - Part No: 1K8 951 171 A
    Coding: 000000
    Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Coding: 18BC32
    Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Coding: 18BC32
    Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
    Part No SW: 6R0 919 475 C HW: 7E0 919 475
    Component: PARKHILFE 4K H11 0013
    Revision: -------- Serial number: 47361206100430
    Coding: 108101
    ASAM Dataset: EV_VW250ParkiAssis2 S01008
    ROD: EV_VW250ParkiAssis2.rod
    VCID: 3E788992A1A0A3EEBD9
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag01M H10 0020
    Revision: -------- Serial number: 003GX015B7UK
    Coding: 00314D
    Shop #: WSC 01383 785 00200
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_SE25.rod
    VCID: 4A90D542ED681F4E111
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB406915IRQ9PTJ
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB406715IRQA9P%
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515RRB404T14TPKIOO3
    Crash sensor for side airbag; rear passenger side:
    Serial number: 352
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
    Component: KOMBI H04 0206
    Serial number: 00000010597376
    Coding: 540E01
    ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
    ROD: EV_DashBoardUDSJCIPQ25_SK25.rod
    VCID: 3A708582BD888FCE811
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0256
    Revision: BF046001
    Coding: 002200
    VCID: F0E4E7AA2374859EFF5
    Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
    Component: IMMO H04 0014
    Serial number:
    ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
    ROD: EV_ImmobUDSJCIPQ25_SK25.rod
    Address 37: Navigation (J794) Labels: 3C0-035-270.clb
    Part No SW: 3C0 035 270 B HW: 3C0 035 270
    Component: RNS310 H20 0357
    Revision: 10000000 Serial number: VWZ1Z2M8467575
    Coding: 060004010400000000000000
    ASAM Dataset: VW_RNS310 A02007
    ROD: EV_VWRNS310UDS.rod
    VCID: 19327A0E184EA4D668B
    4 Faults Found
    1048599 - Rear Left Treble Speaker
    B1066 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 220
    Mileage: 3563 km
    Date: 2012.14.06
    Time: 18:53:48
    1048600 - Rear Right Treble Speaker
    B1068 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 220
    Mileage: 3563 km
    Date: 2012.14.06
    Time: 18:53:48
    1048629 - Aux IN Socket
    B1104 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 220
    Mileage: 3563 km
    Date: 2012.14.06
    Time: 18:53:53
    1048630 - CD Changer
    B1101 31 [009] - No Signal
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Mileage: 3563 km
    Date: 2012.14.06
    Time: 18:53:46
    Address 44: Steering Assist Labels: Redir Fail!
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11220
    Shop #: WSC 00788
    VCID: 2F66A4D6EACA5A6626F
