MMOexp:The Best Diablo 4 Goblin Farm Is Not Infernal Hordes
  • Anselmrosseti
    Auto posseduta: MMOexp
    nome: Anselmrosseti
    da Anselmrosseti » lunedì 15 giugno 2026, 8:45
    The Diablo 4 Goblin Event has officially returned, bringing one of the most rewarding limited-time activities in the game. Treasure Goblins are appearing in huge numbers across Sanctuary, dropping valuable crafting materials, gold, Forgotten Souls, and other resources that players constantly need. But many adventurers are asking the same questions: Where should you farm? What is the fastest way to complete the event? And which locations offer the best rewards? This guide covers everything you need to know about maximizing the Goblin Event, including the best farming routes, reputation rewards, D4 Gold, and several overlooked tricks that can dramatically increase your efficiency.
    What Is the Diablo 4 Goblin Event?
    At first glance, the Goblin Event appears to be a simple reputation grind.
    Players begin in Kyovashad, where a special event quest becomes available. The objective is straightforward: hunt Treasure Goblins and earn event points. Each goblin defeated grants progress toward the event reputation track, allowing players to unlock rewards as they advance.
    The first milestone requires collecting 600 reputation points. Since each goblin contributes a significant amount of progress, completing this initial objective doesn't take long.
    However, many players make a critical mistake.
    They finish the reputation board, collect the rewards, and assume the event is over.
    In reality, the reputation track is only the beginning.
    The Real Purpose of the Event
    The true value of the Goblin Event isn't the reputation board.
    It's the enormous amount of loot and crafting materials generated by farming Treasure Goblins for hours.
    Throughout the event, goblins can drop:
    Gold
    Forgotten Souls
    Crafting materials
    Gem fragments
    Equipment
    Legendary items
    Seasonal resources
    For players struggling with endgame crafting costs, Masterworking expenses, or material shortages, this event can completely solve those problems.
    Think of the reputation rewards as a bonus rather than the primary goal.
    The real objective is maximizing goblin kills.
    Don't Forget to Claim Your Rewards
    One important detail many players overlook is returning to Kyovashad regularly.
    The Goblin Event includes recurring reward caches tied to your total goblin kills. As you continue farming, additional rewards become available from the Goblin Statue.
    If these rewards are not claimed before the event ends, they may disappear permanently.
    To avoid missing valuable loot:
    Farm goblins.
    Check your progress regularly.
    Return to Kyovashad.
    Claim all available caches and rewards.
    This simple habit can significantly increase your overall earnings.
    Why Infernal Hordes Aren't the Best Choice
    One of the first activities players rush into during every Goblin Event is Infernal Hordes.
    While this strategy does have advantages, it isn't ideal if your goal is maximizing event rewards.
    Infernal Hordes can rapidly complete the reputation board thanks to high enemy density and occasional goblin spawns.
    However, there's a major drawback.
    You miss out on many of the direct material drops that make the event so profitable.
    If your only goal is reputation progress, Infernal Hordes work perfectly.
    If your goal is earning gold, crafting materials, and loot, you'll get much better results elsewhere.
    Why The Pit Isn't Worth Farming
    Some players naturally assume that The Pit would be an excellent goblin farming location.
    Unfortunately, that's not the case.
    While Greed Shrines occasionally appear inside Pit runs, most rewards are concentrated at the end of the activity.
    This means you're not consistently benefiting from the increased goblin spawns throughout the event.
    The same issue applies to other activities that delay rewards until completion.
    You may clear content efficiently, but you're sacrificing a large portion of the event's potential value.
    The Best Goblin Farming Location: Nahantu
    For players who own the Vessel of Hatred expansion, Nahantu is arguably the strongest farming location available.
    Several factors make this region exceptional:
    Large open areas
    Fast travel routes
    High goblin density
    Multiple shrine spawn locations
    Excellent visibility for scouting
    Rather than running dungeons repeatedly, players can simply loop through Nahantu's open-world zones while constantly searching for goblins.
    The efficiency is surprisingly high.
    Many players report encountering goblins continuously while following a circular farming route through the region.
    Turn Off Cross-Network Play for Better Results
    One of the most valuable tricks during the Goblin Event has nothing to do with combat.
    Before beginning your farming session:
    Log out of Diablo 4.
    Open the Options menu.
    Navigate to Connectivity settings.
    Disable Cross-Network Play.
    Log back into the game.
    Why does this help?
    During popular events, players often compete for the same Treasure Goblins.
    You may spot a goblin only to discover another player kills it before you arrive.
    Reducing the number of players sharing your instance can dramatically increase the number of goblins available to you personally.
    This simple setting adjustment often leads to noticeably better farming results.
    Use Subo for Maximum Goblin Detection
    Nahantu becomes even stronger when paired with Subo.
    Subo provides a massive advantage because of how goblin detection works.
    Many players rely exclusively on the minimap when searching for Treasure Goblins.
    The problem is that the minimap only reveals nearby targets.
    Subo allows players to effectively detect goblins much farther away than normal.
    By opening the world map periodically, players can identify goblins that would otherwise remain hidden.
    This creates a huge efficiency advantage when farming.
    The Zoom Trick Most Players Miss
    Another important detail involves camera positioning.
    Many players play fully zoomed out.
    During the Goblin Event, that can actually reduce efficiency.
    When farming with Subo:
    Stay moderately zoomed in.
    Avoid maximum zoom distance.
    Check the map frequently.
    Scan surrounding areas before moving.
    At the optimal zoom level, goblin markers become easier to identify and track.
    Combined with Subo's extended detection range, this technique allows players to locate targets much faster than standard gameplay.
    Greed Shrines Are Extremely Valuable
    One of the most powerful mechanics during the event involves Greed Shrines.
    These shrines become significantly more valuable while the Goblin Event is active.
    When activated, Greed Shrines can generate additional goblin opportunities and increase the amount of loot earned from nearby enemies.
    Because of this, experienced farmers constantly search for shrine locations while running their routes.
    Several shrine spawn points exist throughout Nahantu, making the region even more attractive for event farming.
    How to Use Greed Shrines Efficiently
    There is a specific strategy that improves Greed Shrine value.
    Before activating the shrine:
    Avoid killing nearby monsters.
    Scout the surrounding area first.
    Activate the shrine.
    Then eliminate large groups of enemies.
    The more enemies available after activation, the more value you receive from the shrine's effects.
    This small adjustment can lead to significantly better returns over a long farming session.
    PvP Zones Are Another Excellent Option
    Players without access to Nahantu still have strong alternatives.
    The Fields of Hatred PvP zones remain one of the most popular Goblin Event locations.
    Benefits include:
    Open-world exploration
    Frequent goblin sightings
    Fast farming routes
    High enemy density
    Multiple shrine opportunities
    While many players report slightly lower goblin density compared to Nahantu, the difference isn't massive.
    For base-game players, PvP zones remain among the best farming choices available.
    Simply ride through the zone, check your map frequently, and engage every goblin you encounter.
    Hoarfrost Demise Dungeon Farming Strategy
    For players who prefer instance-based farming, Hoarfrost Demise continues to be a fan favorite.
    This dungeon has become a popular Goblin Event strategy due to its quick layout and easy reset process.
    The approach is simple:
    Step 1: Enter the Dungeon
    Begin by clearing only the upper portion of the dungeon.
    Step 2: Search for Shrines
    Look for shrine spawns immediately.
    If no valuable shrine appears, continue quickly through the route.
    Step 3: Kill Any Goblins
    Treasure Goblins can appear inside the dungeon.
    Finding even one or two goblins per run can make the strategy worthwhile.
    Step 4: Reset the Dungeon
    Once the route is complete:
    Leave the dungeon.
    Open the map menu.
    Select Reset Dungeon.
    Re-enter.
    Repeat.
    Because the dungeon is relatively small, this strategy allows players to perform rapid farming loops with minimal downtime.
    Treasure Breach Nightmare Dungeons Are Better Than Ever
    If you still possess Treasure Breach Nightmare Dungeon Sigils, now is the perfect time to use them.
    These dungeons naturally feature Treasure Goblin-related mechanics and become especially rewarding during the event.
    The increased goblin activity can create a massive explosion of loot, making these sigils some of the most profitable content available.
    Although many players have already consumed or replaced their older sigils, anyone holding onto them should strongly consider using them before the event ends buy diablo 4 gear.
    Final Goblin Event Farming Checklist
    Before you begin your farming session, make sure you've completed the following setup:
    ✓ Start the event quest in Kyovashad
    ✓ Progress the reputation board
    ✓ Return regularly to claim reward caches
    ✓ Disable Cross-Network Play
    ✓ Equip Subo if available
    ✓ Stay moderately zoomed in
    ✓ Search for Greed Shrines
    ✓ Farm Nahantu whenever possible
    ✓ Use PvP zones if you don't own the expansion
    ✓ Reset Hoarfrost Demise for dungeon farming
    ✓ Save and use Treasure Breach Nightmare Dungeons
    Conclusion
    The Diablo 4 Goblin Event is far more than a simple reputation grind. While the rewards from the reputation board are valuable, the true strength of the event lies in the enormous amount of materials, gold, Forgotten Souls, and loot generated by continuous Treasure Goblin farming. Players who focus solely on completing the reputation track are leaving a tremendous amount of value on the table.
    Whether you choose to farm Nahantu with Subo, loop through the PvP zones, or repeatedly reset Hoarfrost Demise, the key is maximizing goblin encounters and taking advantage of every Greed Shrine you find. With the right strategy, this event can stockpile enough resources to support weeks of Masterworking, crafting, and endgame progression. If you're short on materials or simply love watching loot explode across the screen, there has never been a better time to hunt goblins in Sanctuary.
