Lettura diagnosi vag...
    juanpalmy
    WEBMASTER
    WEBMASTER
    Feedback: 40
    moto: Beverly 350 Sport T.
    nome: Giovanni
    da juanpalmy » lunedì 19 gennaio 2009, 23:15
    dato che stiamo diventando sempre di piu con il cavo vag e sempre meno a saperlo usare bene... direi di inserire qua i risultati che vengono fuori dalle varie diagnosi per avere un aiuto... inizio io... :003
    diagnosi della macchina di stefano...
    VAG-COM Version: Release 311.2-N
    Chassis Type: 9N1 - VW Polo
    Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
    Address 01 -------------------------------------------------------
    Controller:
    Note: Can't Synch Baud Rate
    Address 03 -------------------------------------------------------
    Controller: 6Q0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0001097
    Shop #: WSC 00788
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 6Q0 820 045
    Component: Klimaanlage X0840
    6 Faults Found:
    01271 - Positioning Motor for Temperature Flap (V68)
    30-10 - Open or Short to B+ - Intermittent
    01596 - Motor for Outside/Recirculated Air Flap (V154)
    28-00 - Short to B+
    29-10 - Short to Ground - Intermittent
    28-10 - Short to B+ - Intermittent
    Address 09 -------------------------------------------------------
    Controller: 6Q1 937 049 C
    Component: 00 BN-SG. 1S32
    Coding: 25742
    Shop #: WSC 00788
    1 Fault Found:
    01598 - Drive Battery Voltage
    07-10 - Signal to Low - Intermittent
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 6Q0 920 820
    Component: KOMBI+WEGFAHRSP VDO V13
    Coding: 01141
    Shop #: WSC 00000
    WVWZZZ9NZ3Y030840 VWZ7Z0B5178818
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: 00 GATEWAY CAN 1S32
    Coding: 00014
    Shop #: WSC 00788
    Address 44 -------------------------------------------------------
    Controller: 6Q0 423 156 M
    Component: LenkhilfeTRW V210
    Coding: 00110
    Shop #: WSC 00788
    Address 46 -------------------------------------------------------
    Controller: 6Q0 959 433 E
    Component: 3P Komfortgerát 0001
    Coding: 00065
    Shop #: WSC 00788
    End --------------------------------------------------
    Re: Lettura diagnosi vag...
    da m2312l » martedì 20 gennaio 2009, 8:06
    Questa è la mia dopo aver cambiato i motoposizionatori... 0 errori :028
    Codice: Seleziona tutto
    Monday,19,January,2009,17:31:24
    VAG-COM Version: Release 512.4-UD
    Chassis Type: 9N - VW Polo
    Scan: 01 02 03 08 09 15 17 19 37 44 45 46 55 56 76
    VIN Number: WVWZZZ9NZ3D111848
    Address 01: Engine
       Part No: 045 906 019 AP
       Component: 1,4l R3 EDC G400SG  1554
       Coding: 00002
       Shop #: WSC 31414
       WVWZZZ9NZ3D111848     VWZ7Z0B6253248
    Readiness: N/A
    Address 03: ABS Brakes
       Part No: 6Q0 907 379 L
       Coding: 0001097
       Shop #: WSC 31414
    Address 08: Auto HVAC
       Part No: 6Q0 820 045
    Address 09: Cent. Elect.
       Part No: 6Q1 937 049 C
       Component: 00 BN-SG.           1S33
       Coding: 09358
       Shop #: WSC 31414
    Address 17: Instruments
       Part No: 6Q0 920 840 M
       Component: KOMBI+WEGFAHRSP VDO X14
       Coding: 01132
       Shop #: WSC 00000
    Address 19: CAN Gateway
       Part No: 6N0 909 901
       Component: 09 GATEWAY  CAN    1S33
       Coding: 00014
       Shop #: WSC 31414
    Address 37: Navigation
       Part No: 1J0 919 887 BX
       Component: Navigation     BNO 0205
       Coding: 00001
       Shop #: WSC 28088
    Address 44: Steering Assist
       Part No: 6Q0 423 156 R
       Component: LenkhilfeKYO        V913
       Coding: 10150
       Shop #: WSC 31414
    Address 45: Inter. Monitor
       Part No: 6Q0 951 171
       Component: Innenraumueberw.    0018
    Address 46: Central Conv.
       Part No: 6Q0 959 433 E
       Component: 4Q Komfortgerát      002
       Coding: 00259
       Shop #: WSC 31414
       Part No: 6Q2959802A
       Component: 4Q Tõrsteuer.FS TFK 0004
       Part No: 6Q2959801A
       Component: 4Q Tõrsteuer.BF TFK 0004
       Part No: 6Q0959811A
       Component: 4Q Tõrsteuer.HL TFK 0004
       Part No: 6Q0959812A
       Component: 4Q Tõrsteuer.HR TFK 0004
    Address 56: Radio
       Part No: 1J0 035 152 GX
       Component: Radio          BNO 0205
       Coding: 06407
       Shop #: WSC 28088
    End   --------------------------------------------------------------------------------------------------
    a proposito, noto che anche stefano è un membro del club dei motoposizionatori andati :012
    da gringo14 » martedì 20 gennaio 2009, 8:45
    Controller:
    Note: Excessive Comm Errors
    Ragazzi, la mia diagnosi in tutti i moduli è ok, ma da sempre sul modulo 3 mi scrive così.....
    La macchina frena e fino ad ora non mi ha mai fatto dubitare di andarmi a piantare da qualche parte.... :003 Però guardando le vostre diagnosi mi sorge un dubbio..... :017 Come mai a me da questo risultato? :017
    da m2312l » martedì 20 gennaio 2009, 8:47
    gringo14 ha scritto:Address 03 -------------------------------------------------------
    Controller:
    Cavo tarocco?
    TheDoCtoR
    Feedback: 9
    nome: Toni Ciccione
    da TheDoCtoR » martedì 20 gennaio 2009, 8:52
    ammazza stefano sarà presidente del club dei motoposizionatori...gli sono partiti quasi tutti :011
    comunque questo è il mio dopo aver messo il FIS quindi sono scomparsi tutti gli errori causati dal cambio tacho andato male.
    Controller: 03C 906 013 B
    Component: MED7.5.11 G 4884
    Coding: 00071
    Shop #: WSC 00000
    WVWZZZ9NZ6Y086862 VWZ7Z0E2338236
    Controller: 6Q0 907 379 AF
    Component: ABS 8.0 front H04 0002
    Coding: 0002169
    Shop #: WSC 00788
    Controller: 6Q0 907 044 C
    Component: CLIMAtronic PQ24 0301
    Coding: 0000000
    Shop #: WSC 00000
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    000 - - - Intermittent
    Controller: 6Q1 937 049 D
    Component: 00AF BN-SG. 1S34
    Coding: 25758
    Shop #: WSC 00788
    Controller: 6Q0 920 842 Q
    Component: KOMBIINSTRUMENT VDO V02
    Coding: 01143
    Shop #: WSC 00000
    Component: 0B7L GATEWAY CAN 1S34
    Coding: 00014
    Shop #: WSC 00788
    Controller: 6Q0 423 156 AB
    Component: LenkhilfeTRW V270
    Coding: 10150
    Shop #: WSC 00788
    Component: 3F Komfortgerát 0002
    Coding: 00019
    Shop #: WSC 00788
    a parte quel maledetto V71 è tutto ok ora...
    non si è più ripresentato l'errore del sensore dei freni...ho solo mosso il cavo, probabilmente non faceva contatto per bene :010
    {Toni}
    :050 La Mia GOLF :050
    da gringo14 » martedì 20 gennaio 2009, 9:25
    Controller:
    Cavo tarocco?
    Beh, il cavo non è proprio professionale, cioè non è come il tuo!!! :018
    Però credo che altri abbiano il mio stesso cavo da 25€ da ebay.... :017 Anzi, credo che oltre a te e Giuseppe con il cavo buono, nessun altro abbia cavi non tarok.... Posso fare qualcosa?
    TheDoCtoR
    Feedback: 9
    nome: Toni Ciccione
    da TheDoCtoR » martedì 20 gennaio 2009, 9:35
    nino l'unica è provare con un altro cavo...così ti togli il dubbio :023
    {Toni}
    da gringo14 » martedì 20 gennaio 2009, 9:46
    TheDoCtoR ha scritto:nino l'unica è provare con un altro cavo...così ti togli il dubbio :023
    Il problema è che nella mia zona nessuno ha il cavo... :012
    Sto pensando sempre più spesso di comprarmi un cavo serio... Ma sono i soldi che non voglio uscire.... Soprattutto ora che praticamente ho finito di fare le modifiche e un cavo economico mi basterebbe..... :009
  • giangiuGTI
    da giangiuGTI » martedì 20 gennaio 2009, 12:59
    giangiuGTI ha scritto:Address 09 -------------------------------------------------------
    Coding: 25742
    Shop #: WSC 00788
    1 Fault Found:
    e questo cosa vuol dire???
    TheDoCtoR
    Feedback: 9
    nome: Toni Ciccione
    da TheDoCtoR » martedì 20 gennaio 2009, 13:43
    Coding: 25742
    Shop #: WSC 00788
    1 Fault Found:
    batteria quasi scarica
    {Toni}
  • giangiuGTI
    da giangiuGTI » martedì 20 gennaio 2009, 13:50
    bene ci avevo visto giusto e abbastanza semplice... insomma... una ciofeca questa macchina!! :003 meno male ha 1 anno di garanzia alla vw... cosi i motoposizionatori li cambiano loro!
    TheDoCtoR
    Feedback: 9
    nome: Toni Ciccione
    da TheDoCtoR » martedì 20 gennaio 2009, 13:59
    giangiuGTI ha scritto:bene ci avevo visto giusto e abbastanza semplice... insomma... una ciofeca questa macchina!! :003 meno male ha 1 anno di garanzia alla vw... cosi i motoposizionatori li cambiano loro!
    si ma diglielo se no vedono l'errore lo tolgono e fanno finta di niente :011
    {Toni}
