VCDS 18.9 NON COMPATIBILE CON POLO AW1
  • ciosas
    Auto posseduta: Polo 1.0 TSI 2017
    nome: Simone
    da ciosas » lunedì 24 dicembre 2018, 13:14
    Buongiorno ragazzi.
    Ho bisogno di aiuto, ho comprato VCDS 18.9 è mi dice che il veicolo non è compatibile.
    Non sono l'unico ad avere questo problema linko i forum:
    1 https://www.vwgolfcommunity.com/vbullet ... -COM-T-Roc
    2 https://forums.ross-tech.com/showthread ... -0-TSI-DSG
    Se accedo su ogni centralina mi da questo log errore:
    Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
    No ASAM data for: "codice centralina" (VW27)
    No fault code found.
    ECCO IL LOG
    Monday,24,December,2018,15:31:18:00007
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.0.2 (x64)
    Data version: 20180927 DS296.0
    www.Ross-Tech.com
    VIN: WVWZZZ+++++66109 License Plate:
    Readiness Status: 0000 0000
    Exhaust Gas Recirculation: Passed
    Oxygen Sensor Heating: Passed
    Oxygen Sensor(s): Passed
    Air Conditioning: Passed
    Secondary Air Injection: Passed
    Evaporative Emissions: Passed
    Catalyst Heating: Passed
    Catalytic Converter(s): Passed
    Monday,24,December,2018,15:32:29:00007
    www.Ross-Tech.com
    VIN: WVWZZ++++ License Plate:
    Address 01: Engine Labels: 04E-907-309-V1.clb
    Control Module Part Number: 04C 906 025 H HW: 04C 907 309 BB
    Component and/or Version: R3 1.0l TFS H20 5177
    Software Coding:
    ASAM Dataset: EV_ECM10TFS01104C906025H 001006 (VW27)
    ROD: N/A
    VCID: 2541479524E1016286-8070
    No ASAM data for: "EV_ECM10TFS01104C906025H" (VW27)
    Readiness: 0000 0000
    Monday,24,December,2018,15:39:08:00007
    www.Ross-Tech.com
    VIN: ++++++ License Plate:
    Chassis Type AW-VW27 (3Q0)
    Scan: 01 02 03 08 09 10 13 14 15 17 19 44 47 55 5F CA
    VIN:
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-DKJA) Labels:. 04E-907-309-V1.clb
    Part No SW: 04C 906 025 H HW: 04C 907 309 BB
    Component: R3 1.0l TFS H20 5177
    Revision: D7H20000
    Coding: 01250032232405080000
    Shop #: WSC 00788 648 00255
    ROD: N/A
    Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
    Part No SW: 0CW 300 042 D HW: 0AM 927 769 E
    Component: GSG DQ200G2_M H05 1612
    Revision: 00005008 Serial number: CU501803255169
    Coding: 0014
    ASAM Dataset: EV_TCMDQ200021 001001
    ROD: N/A
    VCID: 377D+++++++
    No ASAM data for: "EV_TCMDQ200021" (VW27)
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 2Q0 614 517 AA HW: 2Q0 614 517 N
    Component: ESC_base_vFGS H23 0222
    Serial number: 08503955180327
    Coding: 0A034C64354750B332FDAC1624E342A649124D26226A242444541254452442659248B26444562424222A482AA249D64A3D926B52BC
    ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
    ROD: N/A
    VCID: 6DD17FB5BC91F9220E-8038
    No ASAM data for: "EV_Brake1BOSCHESPMQBA0" (VW27)
    La versione è l'ultima 18.9 data 20180927
    NON è ORIGINALE L'INTERFACCIA DIAGNOSTICA VAG, ma su altri veicoli audi skoda volkswagen funziona alla perfezione. Testato anche su vecchi modelli di polo.
    Qualcuno ha già provato VCDS sulla nuova polo AW1 ?
    ciamardo
    nome: Principe
    Re: VCDS 18.9 NON COMPATIBILE CON POLO AW1
    da ciamardo » lunedì 24 dicembre 2018, 15:14
    Ciao , purtroppo è un problema gia noto perchè tutti i cavi clone che si trovano in giro sono basati sul vecchio HW ormai messo fuori produzione due anni fa però ancora supportato dal programma.... per le nuove Polo AW come per il T-Roc dovresti usare le nuove interfacce HEX-V2 o HEX-NET(wifi), però devo essere genuine ovvero originali..
    ATTENZIONE che in rete ultimamente si trovano un sacco di HEX-V2 ma in realtà hanno solo la cover della nuova intefaccia perchè HW interno è sempre quello del vecchio cavo HEX-CAN , quindi occhio :004
    Nel tuo caso con questo cavo non ci puoi fare niente e come alternativa poco costosa ti consiglio OBDeleven in versione Pro a 70€ circa :006
    !!!VAGgo è sono felice!!!
    VCDS Wi-Fi HEX-NET :033
    Cavo VagCanProfessional +K line v2.0
  • ciosas
    nome: Simone
    da ciosas » giovedì 27 dicembre 2018, 20:55
    Grazie mille hai risposto precisamente al mio problema, ho acquistato inutilmente ma ormai lo terrò per utilizzarlo nei vecchi veicoli. Grazie gentilissimo, quindi in poche parole per accedere alla mia polo aw1 basta che acquisto OBDeleven. Grazie
    ciamardo
    nome: Principe
    da ciamardo » venerdì 28 dicembre 2018, 8:17
    si , attualmente OBDeleven risulta il miglior compromesso come qualità/prezzo per la nuova Polo AW1 :004 ,
  • ciosas
    nome: Simone
    da ciosas » venerdì 28 dicembre 2018, 12:48
    Salve entro stasera volevo acquistare Obdeleven pro, mi sono iscritto nel sito ufficiale https://obdeleven.com/en/ chi mi sa dire come funziona? è affidabile il sito? Posso acquistarlo tranquillamente? Una volta acquistato la pro e installato la App come faccio ad ottenere i punti dati durante l'acquisto della Pro nel sito Ufficiale?
    ciamardo
    nome: Principe
    da ciamardo » venerdì 28 dicembre 2018, 13:03
    Si si il sito è affidabile anzi è il sito ufficiale dell'OBDeleven , puoi pagare con PayPal e la spedizione viene fatta tramite la posta ordinaria , spediscono con la poste lituane e in Italia ti arriverà come una raccomandata..ti arriverà in mail il tracking del pacco.... Poi ti consiglio il pro pack a 65€ circa ...... Per i crediti(200) e per attivare la versione Pro nella busta troverai dei codici che inserirai nella App .....
    Inviato dal mio ONEPLUS A3003 utilizzando Tapatalk
  • ciosas
    nome: Simone
    da ciosas » venerdì 28 dicembre 2018, 17:47
    Gentilissimo ti ringrazio ancora, ora procedo al acquisto. Scusa il disturbo, buona serata.
  • padronpolo
    Auto posseduta: Polo aw1
    nome: Raffaele
    da padronpolo » mercoledì 16 gennaio 2019, 13:30
    Ciao, OBDeleven che App ti offre per la Polo AW1?
    polomirko
    da polomirko » venerdì 5 aprile 2019, 12:09
    Ciao sono un neofita di OBD eleven ma ho aperto cmq un thread per la nuova aw1 se interessa:
    viewtopic.php?f=76&t=36498
    Polo 2.0 TSI GTI DSG 6 marce Pure White Cerchi in lega "Milton Keynes" da 7,5 J x 17'' + mirror pack + Videocamera per retromarcia .
    Modifiche: Filtro aria K&N .
  • Santo
    Auto posseduta: Polo 1.2
    nome: Santo
    da Santo » lunedì 6 maggio 2019, 21:19
    ho bisogno di qualcuno che ha una polo 6r 1.2 e che abbia la mia versione di vag vcds 8.9 inglese/italiano. perché nelle guide presenti nel sito le procedure di attivazione sono diverse da ciò che visualizzo io.
    da Bigno82K » martedì 7 maggio 2019, 6:03
    qui si parla del VCDS per polo AW1, quindi oltre a non fare quanto ti ho suggerito negli altri 3D, qui sei pure OT
    ====> REGOLAMENTO<====
    ====>CARICARE IMMAGINI<====
