Lettura diagnosi vag...
    EL MAT
    Auto posseduta: ESCORT COSWORTH
    moto: GSXR 1000
    nome: EL MAT
    Re: Lettura diagnosi vag...
    da EL MAT » giovedì 2 gennaio 2014, 19:58
    oggi per la prima volta ho usato il VCDS e ho fatto un autoscan...
    ci sono degli errori... qualcuno sa aiutarmi?? cosa devo fare??
    Thursday,02,January,2014,11:41:13:65217
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    Data version: 20130910
    VIN: WVWZZZ6RZDY205520 License Plate:
    Chassis Type: 6R (6N0)
    Scan: 01 03 08 09 15 17 19 25 2E 44 55 56
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 MA HW: 03L 907 425 B
    Component: 1,6l R4 CR td H33 9936
    Revision: --H33--- Serial number:
    Coding: 00114016000400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM16TDI02103L 003007
    ROD: N/A
    VCID: 71E3CD84A057DB966BD-8024
    No ASAM data for: "EV_ECM16TDI02103L" (VW36 *)
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP90.clb
    Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
    Component: ESP9.0i front H02 0002
    Serial number: --------------
    Coding: 21DD2885412300C58419146B825100420905
    Shop #: WSC 01383 785 00200
    ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
    ROD: EV_Brake1ESP90iBOSCH_AU21.rod
    VCID: 8F272B7C56A32D669D9-80DA
    6 Faults Found:
    0922 - No Communications with Airbag Control Module
    U0151 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 75
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:03
    0987 - No Communications with Steering Angle Sender (G85)
    U0126 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 40
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:03
    0900 - No Communication with Engine Control Module (SAE ECM/PCM)
    U0100 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 40
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:03
    1049 - No Communication with Engine Control Module (SAE ECM/PCM)
    U0100 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 75
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:03
    0604 - Tire Pressure Warning
    C102D 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 51
    Mileage: 11042 km
    Date: 2008.14.08
    Time: 14:54:53
    0889 - Control Module Incorrectly Coded
    U1014 00 [008] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:08
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
    Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
    Component: Man AC H02 0202
    Revision: 0003SH02
    VCID: 397335A4B0A753D693D-806C
    Address 09: Cent. Elect.
    Cannot be reached
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag01S H10 0020
    Revision: -------- Serial number: 003GX01K7ABF
    Coding: 003153
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW24.rod
    VCID: 4A917A68ED41C84E0A7-801F
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB404T1SEBO8P2A
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB404P1S1NKE1AZ
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515RRB400O4UPT8IQ1X
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525RRB400O4UPT8COG+
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 861 KX HW: 6R0 920 861 KX
    Component: KOMBI H05 0605
    Serial number: 00000000000000
    Coding: 540E01
    Shop #: WSC 00949 264 88299
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
    VCID: 952B5914747FD7B6D75-80C0
    4 Faults Found:
    12648448 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:05
    12669184 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:05
    13638912 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:05
    13639168 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 11757 km
    Date: 2008.14.18
    Time: 01:42:06
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-19.lbl
    Part No SW: 6N0 909 901 HW: 7H0 937 090
    Component: GW-K-CAN TP20 H72 0708
    Revision: B9072001
    Coding: 002000
    Shop #: WSC 12469 483 00190
    VCID: F0E54880235D529EE43-80A5
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0605
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
    ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
    VCID: EAD15AE80D81A84EAA7-80BF
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
    Component: SG EXT.PLAYER H19 0550
    Revision: A1001003 Serial number: 7664194008
    Coding: 010100
    VCID: 2A511AE84501E84EEA7-807F
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 C
    Component: LenkhilfeTRW V278
    Coding: 11220
    Shop #: WSC 00788
    VCID: 30650880F7DD929E243-8065
    Address 55: Xenon Range (J431) Labels: 6R0-907-357.clb
    Part No SW: 6R0 907 357 HW: 6R0 907 357
    Component: LWR-ECU H02 0070
    Revision: -------- Serial number: --------------
    Coding: 0110000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
    ROD: EV_HeadlRegulVWLWRPt.rod
    VCID: F7F7739C4E3305A6259-80A2
    Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
    Component: Radio RCD310 042 0082
    Revision: 01000001 Serial number: VWZ1Z2N1501782
    Coding: 01000400020001
    VCID: 336F078C92CBA986591-8066
    questo è quanto...
    grazie
    MEMENTO AUDERE SEMPER
    guala
    moto: honda cbr 600rr
    nome: andrea
    Re: R: Lettura diagnosi vag...
    da guala » venerdì 3 gennaio 2014, 1:25
    Hai 2 errori , uno nel modulo abs brake, e uno nel modulo instrument. Nel modulo abs brake, ce un problema di comunicazione degli airbag e del sensore angolo sterzo, come se non sono collegati. Hai percaso smontato il volante per montare il cruise control o altro?
    Inviato dal mio GT-S5830 con Tapatalk 2
    EL MAT
    moto: GSXR 1000
    nome: EL MAT
    da EL MAT » giovedì 9 gennaio 2014, 16:50
    no non ho mai smontato il volante... è grave?? provo a pulire gli errori e dopo un pò di giorni ripeto lo scan??
    invece l'altro errore cosa può essere??
    grazie
    da bonzo86 » giovedì 9 gennaio 2014, 19:27
    effettivamente prova a fare così, magari fra 2 giorni fai uno scan.
    EL MAT
    moto: GSXR 1000
    nome: EL MAT
    da EL MAT » giovedì 9 gennaio 2014, 19:56
    per pulire gli errori a fine scan seleziono il pulsante clear all dtc o qualcosa del genere??
    da claudio-dj » giovedì 9 gennaio 2014, 22:58
    esatto!!! :023
    wvpolo
    Auto posseduta: polo 9n1.4tdiex75cv
    moto: rs 125 exstrema
    nome: maurizio
    da wvpolo » mercoledì 15 gennaio 2014, 21:17
    Salve ragazzi anche io ho comprato il cavo o fatto il test e' mi è uscito questo qualcuno mi può aiutare a decifrare la diagnosi? Grazie in anticipo.
    Indirizzo 01 : Etichette del motore: 045-906-019- AMF.clb Codice: 045 906 019 AP Componente : 1,4 a R3 EDC 0200SG 1554 Coding : 00002 Shop # : WSC 00012 VCID : 63CFB7CCF1AB7906E91 - 49D8 WVWZZZ9NZ3D104938 VWZ7Z0B6001094 2 Difetti trovate: 17911 - Caricare segnale da alternatore Term . DF P1503 - 35-10 - non plausibili segnale - intermittente 17571 - Fuel Temp_FINAL Sensor ( G81 ) P1163 - 35-10 - aperto o in corto a Plus - intermittente Readiness : 0 0 X X -------------------------------------------------- ----------------------------- Indirizzo 03 : ABS Freni Etichette: 6Q0 - 907 - 37x - ABS2.lbl Codice: 6Q0 907 379 L Componente: MK60 ABS FRONT 0101 Coding : 0001097 Shop # : WSC 31414 000 00000 VCID : 46894E5832592C2EEEF -5000 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - intermittente -------------------------------------------------- ----------------------------- Indirizzo 08 : Auto HVAC Labels : 6Q0 - 820 - 045.lbl Codice: 6Q0 820 045 Componente: Klimaanlage X0840 VCID : EAD15AE89681A84EAA7 - 5072 1 Fault Found: 65535 - Modulo di Controllo Interno errore di memoria 00-00 - -------------------------------------------------- ----------------------------- Indirizzo 09 : cent . Elect . Etichette: 6QX - 937-049 - C.lbl Codice: 6Q1 937 049 C Componente: SG - 00 Bn . 1S33 Coding : 09358 Shop # : WSC 31414 VCID : 3B7F2FAC299B61C6811 -5000 5 difetti riscontrati : 00511 - Selettore leva ( E313 ) 49-00 - No. Communications 00778 - Sensore sterzo English ( G85 ) 49-00 - No. Communications 01324 - Control Module for All Wheel Drive ( J492 ) 49-00 - No. Communications 01044 - Modulo di controllo non correttamente codificata 35-00 - 01598 - Unit� Tensione della batteria 07-10 - segnale troppo basso - intermittente -------------------------------------------------- ----------------------------- Indirizzo 15 : Etichette Airbag : 6Q0 - 909-605 - VW5.lbl Codice: 1C0 909 605 K Componente: 0L AIRBAG VW51 0006 0P Coding : 12364 Shop # : WSC 31414 VCID : 2C5D1CF0DCF5F67E18B - 5072 1 Fault Found: 00532 - Tensione di alimentazione B + 07-10 - segnale troppo basso - intermittente -------------------------------------------------- ----------------------------- Indirizzo 17 : Etichette Strumenti : 6Q0 - 920 - xxx - 17.lbl Codice: 6Q0 920 800 M Componente: KOMBI + WEGFAHRSP VDO V14 Coding : 01132 Shop # : WSC 00000 VCID : 3777339C15B345A6659 -5000 WVWZZZ9NZ3D104938 VWZ7Z0B6001094 1 Fault Found: 01309 - modulo di controllo del servosterzo ( J500 ) 49-10 - No. Comunicazioni - intermittente -------------------------------------------------- ----------------------------- Indirizzo 19 : CAN Gateway Labels : 6N0 - 909-901 - 19.lbl Codice: 6N0 909 901 Componente: 09 GATEWAY CAN 1S33 Coding : 00014 Shop # : WSC 31414 VCID : F0E54880B05D529EE43 - 5072 4 difetti riscontrati : 00511 - Selettore leva ( E313 ) 49-00 - No. Communications 00778 - Sensore sterzo English ( G85 ) 49-00 - No. Communications 01324 - Control Module for All Wheel Drive ( J492 ) 49-00 - No. Communications 01044 - Modulo di controllo non correttamente codificata 35-00 - -------------------------------------------------- ----------------------------- Indirizzo 44 : Assist Steering Etichette : 6Q0 - 423 - 156.clb Codice: 6Q0 423 156 AA Componente: LenkhilfeKYO V957 Coding : 10150 Shop # : WSC 00000 VCID : 6ED9D6F82A69C46E76F -5000 Colpa No. codificati trovato. -------------------------------------------------- ----------------------------- Indirizzo 46 : Central Conv. . Etichette : 6Q0 - 959 - 433.lbl Codice: 6Q0 959 433 H Componente: 1g Komfortger�t 0002 Coding : 00067 Shop # : WSC 31414 VCID : 40855840407D021ED43 - 49D8 Subsystem 1 - Codice : 6Q2959802A Componente: 1g T�rsteuer.FS TFK 0004 Subsystem 2 - Codice : 6Q2959801A Componente: 1g T�rsteuer.BF TFK 0004 1 Fault Found: Massachusetts , 01038 - Chiusura Centralizzata protezione
    Inviato dal mio LG-P760 utilizzando Tapatalk
    da bonzo86 » mercoledì 15 gennaio 2014, 23:34
    Ma tu noti qualcosa di strano sulla macchina?
    Se è il primo scan prova a cencellare tutto e a rifarlo dopo un paio di giorni e vedi se ti da gli stessi errori
    Inviato dal mio GT-I9300
    wvpolo
    nome: maurizio
    da wvpolo » domenica 19 gennaio 2014, 11:33
    Salve qualcuno sa aiutarmi di come si fa cancellare gli errori su vcds? Grazie in anticipo
    da bonzo86 » domenica 19 gennaio 2014, 11:53
    Clear all dtc's
    da Andreapunk » domenica 19 gennaio 2014, 13:22
    bonzo86 ha scritto:Clear all dtc's
    Bonzo, ma facendo la pulizia errori non si rischia di andare a fare più male che bene?
    wvpolo
    nome: maurizio
    da wvpolo » domenica 19 gennaio 2014, 14:54
    Ok sono riuscito a pulire gli errori, ora mi da questo:
    Domenica 19 gennaio , 2014,15:27:17:65217
    VCD - basato su Windows Wave / VAS Emulator
    VCDS Version : 12.12.0.0
    Versione di dati: 20130910
    VIN : targa WVWZZZ9NZ3D104938 :
    Chilometraggio : 155980 chilometro - 96921mi ordine di riparazione :
    Tipo TELAIO : 9N ( 9N - VW Polo (2002 > 2010) )
    Scansione : 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN : WVWZZZ9NZ3D104938 Chilometraggio : 155980km/96921miles
    Coding : 00002
    Shop # : WSC 00012
    VCID : 63CFB7CCF1AB7906E91 - 4A3A
    Readiness : 0 0 X X
    Coding : 0001097
    VCID : 46894E5832592C2EEEF - 50E6
    Codice: 6Q0 820 045
    Coding : 09358
    Shop # : WSC 31414
    3 Difetti trovate:
    Coding : 12364
    Shop # : WSC 31414
    Possibile colpa della mappatura?
