Lettura diagnosi vag...
    Re: R: Lettura diagnosi vag...
    da McFly » lunedì 1 settembre 2014, 16:16
    Dai un'occhiata qui
    http://audiforum.us/threads/how-to-make-calibration-steering-angle-sensor.15390/
    Sembra che il nuovo sensore vada calibrato in qualche modo
    Edit:
    http://www.bba-reman.com/forums/topic34446-1-1.aspx
  • vwperlavita
    Auto posseduta: polo 4 serie
    nome: matteo
    Re: Lettura diagnosi vag...
    da vwperlavita » lunedì 1 settembre 2014, 16:34
    questo è il risultato della scansione, cosa posso fare? sono nelle vostre mani qui a palermo nessuno sà dove mettere le mani:
    VCDS Version: Release 12.12.0 (x64)
    Data version: 20130910
    Monday,01,September,2014,18:19:20:62939
    Chassis Type: 9N (9N - VW Polo (2002 > 2010))
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ7B013846 Mileage: 59380km/36897miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 03D 906 023 B
    Component: SIMOS91 1.2l 2V 1413
    Revision: --H04--- Serial number: VWZ7Z0G5275838
    Coding: 0000071
    Shop #: WSC 00046 412 147456
    VCID: 1D313FFFC74415F69F5-5000
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 6R0-907-37x-ABS80.lbl
    Part No SW: 6Q0 907 379 AF HW: 6Q0 907 379 AF
    Component: ABS 8.0 front H05 0002
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0002082
    VCID: 8109E38FDBFC51161BD-50E6
    Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
    Part No: 6Q0 820 045
    Component: Klimaanlage X0840
    VCID: EADBA423968AB24EAA7-5072
    Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
    Part No: 6Q2 937 049 F
    Component: 0009 BN-SG. 2S36
    Coding: 17422
    Shop #: WSC 00046
    VCID: 3F8DA5773D8867E6AD9-5072
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 K
    Component: 18 AIRBAG VW51 0P 0010
    Coding: 12600
    Shop #: WSC 00046
    VCID: 2C57E23BDCFEEC7E18B-50E6
    10 Faults Found:
    00595 - Crash Data Stored
    35-00 - -
    01214 - Crash Data for Belt Tensioner Stored
    35-00 - -
    00588 - Airbag Igniter; Driver Side (N95)
    32-10 - Resistance Too High - Intermittent
    00589 - Airbag Igniter 1; Passenger Side (N131)
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    29-10 - Short to Ground - Intermittent
    32-00 - Resistance Too High
    01312 - Powertrain Data Bus
    37-10 - Faulty - Intermittent
    33-10 - Resistance Too Low - Intermittent
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
    Part No: 6Q0 920 804
    Component: KOMBIINSTRUMENT VDO V06
    Coding: 01131
    Shop #: WSC 00000
    VCID: EED3A833AA625E6EF6F-5072
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: 01K1 GATEWAY CAN 2S36
    Coding: 00014
    Shop #: WSC 00046
    VCID: F0EFB64BB056489EE43-5072
    Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
    Component: IMMOBILIZER VDO V06
    Coding: 01131
    Shop #: WSC 00000
    WVWZZZ9NZ7B013846 VWZ7Z0G5275838
    Address 44: Steering Assist Labels: None
    Part No: 8Z0 423 156 K
    Component: LenkhilfeTRW 0210
    Coding: 01260
    Shop #: WSC 00000
    VCID: 428BAC834E7A0A0EC27-5072
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    49-00 - No Communications
    Address 46: Central Conv. Labels: 6Q0-959-433.lbl
    Part No: 6Q0 959 433 H
    Component: 1D Komfortgerát 0002
    Coding: 00019
    Shop #: WSC 00046
    VCID: 408FA68B4076181ED43-4A3A
    VCDS Versione: Rilasciare 12.12.0 (x64)
    Versione dei dati: 20130910
    Lunedi, 01 settembre, 2014,18: 19: 20: 62939
    Telaio Tipo: 9N (9N - VW Polo (2002> 2010))
    Scansione: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ7B013846 Chilometraggio: 59380 chilometri / 36897 miglia
    Indirizzo 01: Etichette motore: Redir Fail!
        Codice: 03D 906 023 B
        Componente: SIMOS91 1.2L 2V 1413
        Revisione: --H04 --- Numero di serie: VWZ7Z0G5275838
        Coding: 0000071
        Negozio #: WSC 00046 412 147456
    Nessun codice di errore trovato.
    Readiness: N / A
    Indirizzo 03: Freni ABS Etichette: 6R0-907-37x-ABS80.lbl
        Componente: ABS 8.0 front H05 0002
        Revisione: 00000000 Numero di serie: 00000000000000
        Coding: 0002082
    Indirizzo 08: Auto HVAC Labels: 6Q0-820-045.lbl
        Componente: Klimaanlage X0840
    Indirizzo 09: Cent. Elect. Etichette: 6QX-937-049-C.lbl
        Componente: 0009 BN-SG. 2S36
        Coding: 17422
    Indirizzo 15: Etichette Airbag: 6Q0-909-605-VW5.lbl
        Codice: 1C0 909 605 K
        Componente: 18 AIRBAG VW51 0P 0010
        Coding: 12600
    10 Guasti Trovato:
    00595 - Crash dati memorizzati
                 35-00 - -
    01214 - Dati Crash per Tendicinghia Stored
                 35-00 - -
    00588 - Airbag Accenditore; Autista Side (N95)
                 32-10 - Resistenza troppo alta - intermittente
    00589 - Airbag Accenditore 1; Passenger Side (N131)
    00654 - Cintura di sicurezza tenditore Igniter; Lato conducente (N153)
    00655 - Cintura di sicurezza tenditore Igniter; Passenger Side (N154)
                 29-10 - Cortocircuito verso terra - intermittente
                 32-00 - Resistenza troppo alta
    01312 - Powertrain bus dati
                 37-10 - difettoso - intermittente
                 33-10 - Resistenza troppo bassa - intermittente
    00532 - Tensione di alimentazione B +
                 07-10 - Segnale troppo basso - intermittente
    Indirizzo 17: Etichette Strumenti: 6Q0-920-xxx-17.lbl
        Componente: Kombiinstrument VDO V06
        Coding: 01131
        Negozio #: WSC 00000
    Indirizzo 19: CAN Gateway Etichette: 6N0-909-901-19.lbl
        Codice: 6N0 909 901
        Componente: 01K1 GATEWAY CAN 2S36
        Coding: 00014
    Indirizzo 25: Etichette immobilizzatore: 5J0-920-xxx-25.clb
        Componente: IMMOBILIZER VDO V06
        Coding: 01131
    Indirizzo 44: Steering Assist Etichette: Nessuno
        Codice: 8Z0 423 156 K
        Componente: LenkhilfeTRW 0210
        Coding: 01260
    1 Fault Found:
    Indirizzo 46: Central Conv​​. Etichette: 6Q0-959-433.lbl
        Componente: 1D Komfortgerát 0002
        Coding: 00019
    fine ------------------------------------------------- --------------------
    da claudio-dj » lunedì 1 settembre 2014, 16:57
    Sono tutti errori dovuti ad un qualche incidente fatto precedentemente... O adesso... Ora nn saprei la situazione della tua auto...
    Quindi probabilmente gli errori sono correlati e se nn azzeri quelli riferiti ai sistemi di sicurezza,tutto il resto ti rimane in blocco!
  • vwperlavita
    nome: matteo
    da vwperlavita » lunedì 1 settembre 2014, 17:28
    Come posso azzerararli visto che non me l cancella? PS: è lo sterzo duro mi sai dire cosa è?
    da McFly » lunedì 1 settembre 2014, 19:14
    Per lo sterzo prova così, è per golf ma almeno ti fai un'idea e puoi provare..
    Taratura a zero del trasduttore angolo di sterzata -G85 :
    Nei casi per i quali si è impiegato finora il lettore guasti V.A.G 1551 si può utilizzare adesso il tester VAS 5051.
    ‒ Collegare il lettore guasti V.A.G 1551 e selezionare la centralina per elettronica dei freni ad accensione inserita (indirizzo 03);
    ‒ Avviare il veicolo.
    ‒ Fare un breve giro di prova su un tragitto piano, marciando in rettilineo. Non superare i 20 km/h. Prestare attenzione ai seguenti punti:
    ◆ se, marciando in rettilineo, il volante non si trova in mezzaria, correggere la posizione del volante nel corso di una misurazione del telaio
    => Telaio, assali, sterzo - trazione anteriore e integrale; Misurazione del veicolo
    ◆ se, marciando in rettilineo, il volante rimane in mezzaria, fermare il veicolo esattamente in questa posizione
    ‒ Controllare i valori misurati avviando la funzione 08 "lettura blocco valori di misurazione" n. indicatore di gruppo 004.
    Attenzione a non modificare più la posizione del volante. Non disinserire l'accensione!
    ● Eseguire la funzione 11 "procedura di login" utilizzando il lettore guasti V.A.G 1551
    → Indicazione sul display: Trasmissione rapida dati HELP
    Immettere indirizzo XX
    ‒ Premere i tasti 0 e 4. (Con 04 viene selezionata la funzione "Avviare la registrazione di base").
    → Indicazione sul display: Trasmissione rapida dati Q
    04 Avviare la registrazione di base
    ‒ Confermare l'immissione mediante il tasto Q.
    → Indicazione sul display: Registrazione base HELP
    Immettere numero indic. gruppo XXX
    ‒ Premere i tasti 0, 6 e 0.
    ‒ La spia di controllo ABS lampeggia.
    → Indicazione sul display: Sistema in registrazione di base 60
    Taratura OK 0.05
    → Se sul display appare la seguente visualizzazione, vuol dire che la "Procedura Login" non è stata effettuata con il dovuto successo. Funzione sconosciuta oppure - ⇒
    momentaneamente non eseguibile
    ‒ oppure:
    → Se sul display appare la seguente visualizzazione, vuol dire che i valori misurati non rientrano nel campo di tolleranza consentito della taratura a zero. Sistema in registrazione di base 60
    Taratura non possibile 12.5
    ‒ Controllare i valori misurati avviando la funzione 08 "lettura blocco valori di misurazione" , n. indicatore di gruppo 004.
    1. interrogare la memoria guasti (funzione 02)
    2. cancellare la memoria guasti (funzione 05)
    3. fine emissione (funzione 06)
    4. disinserire l'accensione
    5. inserire l'accensione
    6. ripetere la taratura a zero
    ‒ Premere il tasto ⇒.
    ‒ Premere i tasti 0 e 6, in maniera da portare a termine le emissioni.
    → Indicazione sul display Trasmissione rapida dati Q
    06 Fine emissioni
    ‒ Le spie di controllo ABS e ESP si accendono per ca. 2 secondi.
    Comunque hai ben 10 errori riguardo l'airbag. Io direi di risolvere quelli per primi.
    O cambi elettrauto o vai in un ufficiale VW
    mdxspecial90
    Auto posseduta: 1.2 tsi
    da mdxspecial90 » giovedì 4 settembre 2014, 12:07
    amici, son alle prime armi con il vag, quindi scusate se commetto qualche errore o simili.... ho fatto l'autoscan, il cavo mi è arrivato stamattina (preso qui sul forum)
    mi ha dato il messaggio/fumetto: no ROD file foud (penso non sia un problema, c'entra solo con la versione del cavo/software?)
    poi è comparsa in rosso la scritta address 01: engine ma ha dato poi nel log nessun errore. posto di seguito il log dell'autoscan, a voi sembra tutto a posto?
    Thursday,04,September,2014,13:49:03:62939
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.0.0
    VIN: WVWZZZ6RZCY036537 License Plate:
    Chassis Type: 6R (6N0)
    Scan: 01 03 08 09 15 17 19 25 44
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
    Part No SW: 03F 906 070 HE HW: 03F 907 309 J
    Component: SIMOS10.22H03 5459
    Revision: --H03--- Serial number:
    Coding: 001900D6200400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM12TFS02103F 004007
    ROD: N/A
    VCID: 6CD7223B877E2C7E58B-8039
    No ASAM data for: "EV_ECM12TFS02103F" (VW25)
    Readiness: 0000 0000
    VCID: 55A167DFACF48DB6975
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
    Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
    Component: Man AC 02 0101
    Revision: 0002S 02
    VCID: 326BFC436DDABA8E527-8067
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0251
    Revision: BF046001 Serial number: 0434 172110433
    Coding: 24B029BF08A10000002008002D2B0CD00040410F60060000200000000000
    Shop #: WSC 124697 483 00190
    VCID: 4581B79FCC543D36E75-8010
    Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 008 1621
    Coding: 08BC30
    Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 008 1621
    Coding: 08BC30
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag01S H09 0020
    Revision: -------- Serial number: 003GX00R2U3S
    Coding: 003153
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW24.rod
    VCID: 4A9B84A3ED4AD24E0A7-801F
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB40650CTC4F0J9
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB404T0H4DK48QX
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515RRB404V0M8GC6OJA
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525RRB405H0LCOQ7HSQ
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 860 H HW: 6R0 920 860 H
    Component: KOMBI H03 0505
    Coding: 140A01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
    ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
    VCID: 3979CB6FB8AC49D693D-806C
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0251
    Revision: BF046001
    Coding: 002000
    VCID: F0EFB64B2356489EE43-80A5
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0505
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
    VCID: EADBA4230D8AB24EAA7-80BF
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11250
    Shop #: WSC 00788
    VCID: 2F6DF537EAE897663D9-807A
    JacopoPolo
    nome: Jacopo Carnevale
    da JacopoPolo » domenica 7 settembre 2014, 13:50
    Per favore controllatemi un pò la situazione perché sto uscendo pazzo, non riesco nemmeno ad entrare in alcuni canali e non capisco perché. Forse tutto parte da qua...
    Sunday,07,September,2014,15:35:30:62939
    VIN: WVWZZZ6RZDY047060 License Plate:
    Scan: 01 03 08 09 15 17 19 25 2E 44 56
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 210224E3217100B9842524E884D100401100
    VCID: 820BEC8319FA4A0E027-80D7
    Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
    Component: Man AC H02 0202
    Revision: 0003SH02
    VCID: 3979CB6FB0AC49D693D-806C
    Component: BCM PQ25 H+4 H46 0254
    Revision: BF046001 Serial number: 0434 181120362
    Coding: 3CB02BBF08B30000003808006D2B0CD00040412F60860000200000000000
    Shop #: WSC 12469 483 00190
    Component: J386__TSG_FT 008 1611
    Coding: 18BC30
    Component: J387__TSG_BT 008 1611
    Coding: 18BC30
    Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Coding: 18BC32
    Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Coding: 18BC32
    Component: VW10Airbag01M H10 0020
    Revision: -------- Serial number: 003GX01B32M5
    Coding: 00314D
    Shop #: WSC 01383 785 00200
    Serial number: 3575HRB40671E4S2B05S
    Serial number: 3585HRB40671EGVOBGOF
    Serial number: 3515RRB40144UJ4OH8P4
    Serial number: 3525RRB400S4UH2481IO
    Part No SW: 6R0 920 860 K HW: 6R0 920 860 K
    Component: KOMBI H04 0605
    Coding: 140200
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    VCID: 3C77D27BB79E7CFE88B-8069
    1 Fault Found:
    12648448 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 121
    Mileage: 22590 km
    Date: 2024.14.07
    Time: 15:33:25
    Component: GW-K-CAN TP20 H46 0254
    Revision: BF046001
    Coding: 002200
    Component: IMMO H04 0605
    Serial number:
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
    Address 2E: Media Player 3
    Cannot be reached
    Coding: 11210
    Shop #: WSC 00788
    1 Fault Found:
    01314 - Engine Control Module
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 5K0 035 190 B HW: 5K0 035 190 B
    Component: Radio RCD510 005 0234
    Revision: 00000001 Serial number: VWZ1Z3M7274555
    Coding: 01010000010008
    Shop #: WSC 00040 040 00001
    VCID: 24470A1B272E243ED0B-8071
    Ultima modifica di JacopoPolo il domenica 7 settembre 2014, 14:19, modificato 1 volta in totale.
    da bonzo86 » domenica 7 settembre 2014, 14:10
    Mdxspecial non hai nessun errore. Hai solo un problemino con il file rod.
    Jacopo hai postato due scan. Pare che però ci sono dei problemi con la centralina motore. Mancata comunicazione
    Inviato dal mio GT-I9300
    JacopoPolo
    da JacopoPolo » domenica 7 settembre 2014, 14:19
    bonzo86 ha scritto:Mdxspecial non hai nessun errore. Hai solo un problemino con il file rod.
    Modificato! Comunque non solo quello anche altri due se non sbaglio. Sai come potrei risolvere?
    da bonzo86 » domenica 7 settembre 2014, 14:29
    Recati in una officine e fatti fare una diagnosi con un bosch, wurth o breinbee
    mdxspecial90
    da mdxspecial90 » domenica 7 settembre 2014, 19:08
    Il mio file rod colpa del vag 12.12 non pienamente compatibile, appena ho l'11 controllo bene la parte del motore/engine.. Grazie ;)
    JacopoPolo
    da JacopoPolo » domenica 7 settembre 2014, 19:34
    bonzo86 ha scritto:Recati in una officine e fatti fare una diagnosi con un bosch, wurth o breinbee
    Con quale scusa faccio controllare? Sicuramente non posso dire di avere un cavo e di aver fatto la diagnosi
Visitano il forum: Nessuno e 23 ospiti
