,che ha lo spinotto molto spesso e sembra incastrato ma la certezza non la posso dare
Codice: Seleziona tutto
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.lbl
Part No SW: 03L 906 023 D HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 8867
Revision: --H13---
Coding: 00114016002400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023D 003007
ROD: EV_ECM16TDI02103L906023D.rod
VCID: 2756E718EF6B
2 Faults Found:
6056 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - Implausible Signal
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 5
Mileage: 29291 km
Date: 2020.14.16
Time: 04:49:12
6117 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 29291 km
Date: 2020.14.16
Time: 04:49:05
Readiness: 0000 0000Codice: Seleziona tutto
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.lbl
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001
Coding: 24B02BBF08A10000003800003D2B0CD00080410F60060000200000000000
Shop #: WSC 00046 412 73728
VCID: 40845C846A05
Part No SW: 6R0 959 801 R HW: 6R0 959 801 R
Component: J386__TSG_FT 006 0903
Coding: 18BC30
Part No SW: 6R0 959 802 T HW: 6R0 959 802 T
Component: J387__TSG_BT 006 0902
Coding: 08BC30
Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 020000
Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Coding: 08BC32
Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Coding: 08BC32
No fault code found.
Visitano il forum: Nessuno e 19 ospiti
