La POLO di LuchinoTDI - ABT Power
    Luchino GTI
    Auto posseduta: Polo 9N3 GTI
    nome: Luca
    Re: La POLO di LuchinoTDI .:.
    da Luchino GTI » mercoledì 23 gennaio 2013, 18:16
    Dopo aver riscontrato dei problemi quali, non funziona più il finestrino SX anteriore, e all'estrazione della chiave le porte non si aprono, ho fatto una diagnosi con il VAG e ho riscontrato i seguenti errori, che sono?
    Wednesday,23,January,2013,18:37:09:37412
    VCDS Version: Release 10.6.4 (x64)
    Data version: 20110418
    Chassis Type: 9N - VW Polo
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ7Y080512 Mileage: 109650km/68133miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 045 906 019 CA
    Component: 1,4l R3 EDC 0400SG 8400
    Coding: 00002
    Shop #: WSC 00788
    VCID: 56A9F7FC9897
    WVWZZZ9NZ7Y080512 VWZ7Z0F4446786
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
    Part No SW: 6Q0 907 379 AS HW: 6Q0 907 379 AS
    Component: ESP 8.0 front H05 0003
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0002368
    Shop #: WSC 00788 785 00200
    VCID: 8E195F9CE0C7
    Address 08: Auto HVAC Labels: None
    Part No: 6Q0 907 044 E
    Component: CLIMAtronic PQ24 3805
    Shop #: WSC 00000 000 00000
    VCID: 346D6D742EAB
    1 Fault Found:
    01273 - Fresh Air Blower (V2)
    000 - - - Intermittent
    Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
    Part No: 6Q1 937 049 D
    Component: 00BP BN-SG. 1S34
    Coding: 09358
    Shop #: WSC 00788
    VCID: 3C7D455406FB
    1 Fault Found:
    00969 - Fuse for Heated Rear Window (S41)
    37-10 - Faulty - Intermittent
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 K
    Component: 18 AIRBAG VW51 0P 0009
    Coding: 12600
    Shop #: WSC 00788
    VCID: 2C5D7514F69B
    Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
    Part No: 6Q0 920 804 K
    Component: KOMBIINSTRUMENT VDO V03
    Coding: 01132
    Shop #: WSC 00000
    VCID: 39735C4009C9
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: 01K1 GATEWAY CAN 1S34
    Coding: 00014
    Shop #: WSC 00788
    VCID: F0E521649A33
    Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
    Component: IMMOBILIZER VDO V03
    Coding: 01132
    Shop #: WSC 00000
    VCID: 39735C4009C9
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6Q0 423 156 AB
    Component: LenkhilfeTRW V270
    Coding: 10150
    Shop #: WSC 00788
    VCID: 6FE7A218070D
    Address 45: Inter. Monitor Labels: None
    Part No: 6Q0 951 171 C
    Component: Innenraumueberw. 0020
    VCID: 32616B6CD4BF
    Address 46: Central Conv. Labels: 6Q0-959-433.lbl
    Part No: 6Q0 959 433 E
    Component: 64 Komfortgerát 0002
    Coding: 00019
    Shop #: WSC 00788
    VCID: 3D7B48501DE1
    1 Fault Found:
    00849 - S-contact at Ignition/Starter Switch (D)
    25-00 - Unknown Switch Condition
    :017
  • polozza92
    Auto posseduta: polo 9n
    nome: flavio
    da polozza92 » mercoledì 23 gennaio 2013, 23:13
    Luchino TDI ha scritto:Dopo aver riscontrato dei problemi quali, non funziona più il finestrino SX anteriore, e all'estrazione della chiave le porte non si aprono, ho fatto una diagnosi con il VAG e ho riscontrato i seguenti errori, che sono?
    Coding: 00002
    Shop #: WSC 00788
    VCID: 56A9F7FC9897
    Coding: 0002368
    VCID: 8E195F9CE0C7
    VCID: 346D6D742EAB
    1 Fault Found:
    Coding: 09358
    Shop #: WSC 00788
    VCID: 3C7D455406FB
    1 Fault Found:
    Coding: 12600
    Shop #: WSC 00788
    VCID: 2C5D7514F69B
    Coding: 01132
    Shop #: WSC 00000
    VCID: 39735C4009C9
    Coding: 00014
    Shop #: WSC 00788
    VCID: F0E521649A33
    Coding: 01132
    Shop #: WSC 00000
    VCID: 39735C4009C9
    Coding: 10150
    Shop #: WSC 00788
    VCID: 6FE7A218070D
    VCID: 32616B6CD4BF
    Coding: 00019
    Shop #: WSC 00788
    VCID: 3D7B48501DE1
    1 Fault Found:
    :017
    hooo cacchio e arabo per me :017 :017 :017
    mi dispia ma sta volta non so come aiutarti luca.
    sono proprio ignorante su questo campo.
    ma il mio amico poi lo hai più chiamato ???
    Luchino GTI
    nome: Luca
    da Luchino GTI » mercoledì 23 gennaio 2013, 23:43
    Ciao Flavio! No non l'ho più chiamato xkè ne ho avute di ogni questa settimana, ho dannato 2giorni per farmi sostituire l'autoradio che avevo appena comprato xkè era difettosa, mi sono arrivate le griglie per la polo ed erano rotte! ora questo problema che non so da dove venga e cosa sia è una settimana allucinante!
    Domani mattina il mio elettrauto i prende su la macchina e prova a dargli un'occhiata e vediamo se capisce il problema...
    Ho comunque postato la diagnosi del VAG anche nella sezione apposta, speriamo che qualcuno risponda perché l'ultimo post risaliva al 23 dicembre...
    Te tutto bene?
    Sistemato la polo?
    Sto scrivendo dall'iPhone...
  • xax
    nome: xax
    da xax » sabato 26 gennaio 2013, 11:46
    ciao luchino digita su google eletrauto oline rone63 ma e preferibile contatarlo su facebook ha la foto di un cane,e molto bravo spiegali il tuo problema :003
    Luchino GTI
    nome: Luca
    da Luchino GTI » sabato 26 gennaio 2013, 13:22
    Grazie 1000 stasera provo a contattarlo, spero non sia saltato il motorino di avviamento...
    Un'altra cosa, sulla nostra polo l'unica scatola dei fusibili è quella sul lato sinistro della plancia giusto?
  • xax
    nome: xax
    da xax » sabato 26 gennaio 2013, 13:30
    diciamo di si,gli altri fusibili stanno nel coperchietto vicino alla batteria dell auto nel cofano anteriore,kmq fami sapere :048
    Luchino GTI
    nome: Luca
    da Luchino GTI » sabato 26 gennaio 2013, 14:21
    Ho appena controllato tutti i fusibili sulla sinistra della plancia e sono tutti ok li ho tolti 1ad1...
    Stasera provo a controllare quelli nel cofano...
    Vi faccio sapere!
    Grazie 1000
  • xax
    nome: xax
    da xax » sabato 26 gennaio 2013, 14:31
    controlla bene i fusibili,dalla parte del cofano anteriore sono in una specie di scatoletta nera,i fusibili non sono tanti kmk se proprio non riesci contata rone 63 su facebook
    Luchino GTI
    nome: Luca
    da Luchino GTI » lunedì 28 gennaio 2013, 0:06
    Purtroppo causa lavoro non sono riuscito a sistemare la Polo :022
    Oltretutto stamattina ho avuto un nuovo problema, praticamente stamattina e anche stasera all'accensione della macchina i 2 display quello dell'ora e dei chilometri si illuminano ma non segnavano nessun dato erano semplicemente illuminati di blu, accendendo e rispegnendo la macchina tutto torna normale...
    Se domani mattina rifà questo problema ne posto una foto :023
  • Darx
    Auto posseduta: Polo 9n 1.4 16v 75hp
    nome: Gianmarco
    da Darx » lunedì 28 gennaio 2013, 12:55
    Ciao, hai provato a riportare l'auto allo stato originale con il vag??
    Intendo togliere tutto quello che avevi messo e far passare qualche ora in modo che la centralina si resetti automaticamente e vedere se va tutto bene.. a quel punto rimetti tutte le modifiche una alla volta vedendo quale da problemi.
    Cosa c'è di meglio di una vw????
    Luchino GTI
    nome: Luca
    da Luchino GTI » venerdì 1 febbraio 2013, 20:47
    Giorno gente!
    Oggi ho fatto fare il tagliando alla Polo dal mio meccanico di fiducia, 100€ direi ottimo :003
    (Intanto che mi faceva il lavoro io era a casa sua a sistemargli il PC per quello il buon prezzo :023 )
    Mi ha però detto che ho i dischi posteriori andati e quelli anteriori sarebbe meglio sostituirli...
    Quindi cosa mi consigliate di diverso dagli originali? senza dover vendere un rene :003
    da McFly » venerdì 1 febbraio 2013, 21:05
    i brembo lisci
