Guida per attivare XDS
    ciclo
    Auto posseduta: 1.2 TSI R-Line
    Re: Guida per attivare XDS
    da ciclo » sabato 16 marzo 2013, 5:41
    Thanks to the authors of this post and your great work. :038
    I was contacted by mp ciamardo but after translating the entire post (hard work) I see that there are more people that I must thank this great mod.
    My results are:
    VW POLO 1.2 TSI 90CV
    XDS ON, HILL HOLDER OFF,TPMS ON
    VCDS Version: Release 11.11.3
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 210228E3216D00B5842814EA84D300401600
    Shop #: WSC 00788 648 00255
    VCID: 820114D11914B09
    No fault code found.
    Channel 36 to 0.
    Sensations in fast curve: (personally)
    The XDS system acts just as it should, and the only thing I can see is that the front is positioned better without make small corrections to the steering wheel.
    The fans pull the handbrake and go making corrections with the steering wheel will understand me. :010
    Everything has a limit, but if we force the ESP comes into operation (control light flashes) and has given me the feeling of being less intrusive.
    I really liked this change.
    Grazie. Saluti. :006
    PD: Forza Ferrari, Forza Fernando Alonso, Felipe Massa Forza. (MG, PDLR, e tutto il personale tecnico.). Inizia tra breve GP classificazione in Australia.
    POLO 6R 1.2 TSI 90CV R-LINE BIANCO 5p
    ciclo
    da ciclo » domenica 17 marzo 2013, 22:47
    A friend has a VW Polo 1.2 TSI R-Line 2013 and this is the ABS unit. ESP9.0i front H01 0002
    The image is testing we were doing, but not correct.
    We are trying to configure the XDS. He has no experience with vcds. The adaptation is drop down, not channels. When it is done, I will inform.
    Ultima modifica di ciclo il martedì 19 marzo 2013, 6:54, modificato 1 volta in totale.
    ciclo
    da ciclo » lunedì 18 marzo 2013, 20:30
    Today we tried to enable the XDS but it was not possible.
    Marking the bit 2 byte 16 with this unit ABS function XDS is not enabled in the dropdown. Light comes on warning brake system in the instrument cluster.
    An image of the dropdown adaptation.
    Any help is appreciated.
    Saluti.
    Ultima modifica di ciclo il giovedì 21 marzo 2013, 6:35, modificato 1 volta in totale.
    ciamardo
    nome: Principe
    da ciamardo » martedì 19 marzo 2013, 18:42
    ciclo ha scritto:Today we tried to enable the XDS but it was not possible.
    hola
    you can post here the complete ABS logfile of this Polo MY2013???? :039
    !!!VAGgo è sono felice!!!
    VCDS Wi-Fi HEX-NET :033
    ciclo
    da ciclo » mercoledì 20 marzo 2013, 2:03
    Hola ciamardo. Un placer saludarte. :occ
    The long coding with byte16..bit2 ticked.
    21DD4885232700C8841A126DC45300400D05
    Image:
    We have tried to mark and unmark bitwise (0 to 7, except the original marked 0 and 3), but in the dropdown no change adaptation.
    The logfile, I have to ask him to send it to me.....I ask him tomorrow. :006
    ciamardo
    nome: Principe
    da ciamardo » mercoledì 20 marzo 2013, 19:18
    ciclo ha scritto:Hola ciamardo. Un placer saludarte. :occ
    Image:
    Hola
    Su amigo tiene la versión ABS que funciona en el nuevo protocolo UDS
    Yo creo que no cambia el byte 16, ya que es el mismo para todos los polos
    example:
    Polo 1.2 TDI MY2013
    Teilenummer SW: 6R0 907 379 AS HW: 6R0 907 379 AS
    Bauteil: ESP9.0i front H01 0002
    Seriennummer: --------------
    Codierung: 21DD2485412600C88417246C825500420904
    Creo que se necesita para cambiar el byte 17 :017
    para mí:
    BIT 0 --------> Hill Hold -------------> ticked
    BIT 1 --------> XDS???
    BIT 2 ---------> ??? ----------->ticked
    Bit 3 ----------> ???
    debe confirmar mis teorías :033
    ciclo
    da ciclo » mercoledì 20 marzo 2013, 20:02
    "Muchas gracias" ciamardo por tu incondicional ayuda y por tu tiempo. :038
    I will report when we verify the byte 17. :game
    crt
    moto: vespa, renegade 500
    nome: ciccio
    da crt » mercoledì 20 marzo 2013, 22:41
    eccomi qui dopo aver fatto la prova ad attivare l'xds sulla mia polo 2013..
    il codice lo accetta (byte 16, bit 2), mi esce scritto codice accettato.... però non capisco perchè non ho la possibilità di entrare nelle adptation..... non mi da proprio la possibilità di entrarci, forse perchè sto usando la vcds 10.6.5?? :017
    qualcuno potrebbe darmi una versione più aggiornata in modo da poter provare con quella??
    il numero della mia centralina Abs è: esp9.0i front h02 0002
    il coding di partenza è 21DD2885412A00C38414146B825700420905
    e dopo la modifica ho il seguente coding: 21DD2885412A00C38414146B825700420D05
    ecco come mi si presenta la schermata:
    Uploaded with ImageShack.us
    e poi mi esce questa cosa, che mi fa intendere che devo aggiornare la versione di vcds...help!:
    crt
    nome: ciccio
    da crt » mercoledì 20 marzo 2013, 23:00
    dal sito ross-tech ho scaricato l'ultima versione la 11.11.5 spero funzioni col mio cavo (11.11), ciamardo secondo te? stavo pensando di usare la versione 11.11.3 ma non l'ho trovata
    domani provo e vi saprò dire :023
    da Federicodrdpro » mercoledì 20 marzo 2013, 23:14
    Se hai il cavo clone e scarichi versioni aggiornate del VCDS dal sito, ti si sprogramma il cavo.
    crt
    nome: ciccio
    da crt » giovedì 21 marzo 2013, 7:30
    Ho il cavo che vende domsaimond.....quindi che versione dovrei installare per non avere problemi?
    Meno male che me l'hai detto sennò stamattina sarei andato a collegarlo all'auto e ciao ciao cavo
    ciamardo
    nome: Principe
    da ciamardo » giovedì 21 marzo 2013, 11:27
    crt ha scritto:eccomi qui dopo aver fatto la prova ad attivare l'xds sulla mia polo 2013..
    Ciao la tua polo dispone della nuova centralina esp9.0i che sfrutta il nuovo protocollo UDS ( vedi i screen postati da ciclo) quindi niente channel in adaption ma solo una lista da cui selezionare le opzioni però la tua versione del vcds 10.6.5 è troppo datata infatti devi usare una versione più recente!!
    Poi per xds aspettiamo ciclo con i suoi test perché i bit da selezionare sono diversi in queste esp9.0i!!
