AMPLIFICATORE ESX VISION VE 1800.2 1800 W
USATO GARANTITO 1 ANNO DI VITA ,PER IMPIANTO AUDIO
AD ALTA PROFESSIONALITA'
PREZZO NUOVO 600 EURO, POTETE VERIFICARLO SU GOOGLE
USATO
PREZZO: (S.S. Escluse)
350
TRATTABILE
SI
SPESE SS
15
TIPOLOGIA GARANZIA:
VISTO E PIACIUTO
DESCRIZIONE:
VENDO PER SMONTAGGIO IMPIANTO,USATO UN ANNO SCARSO CON GARANZIA DI ALTISSIMO LIVELLO.
CHI SE NE INTENDE DI CAR AUDIO SA BENISSIMO DI CHE MODELLO DI AMPLIFICATORE SI TRATTA.
COME DALLA FOTO SI E' SMARRITO UN CONNETTORE DI 2 EURO IN USCITA AL CANALE CHE CONSENTE IL COLLEGAMENTO CON UN ALTRO AMPLIFICATORE( PERALTRO MAI USATO E QUASI INUTILE ).
INOLTRE MAI SFRUTTATO ALLA MASSIMA CAPACITA' PERCHE AD ESSO ERANO ATTACCATI SIA I WOOFER E SIA I TWETER.ELENCO LE CARRATTERISTICHE:
Class A/B Analog Amplifier
2 x 400 Watts RMS @ 4 Ohms
2 x 700 Watts RMS @ 2 Ohms
2 x 900 Watts RMS @ 1 Ohms
Highpass Filter 10 Hz - 2.5 kHz
Lowpass Filter 40 Hz - 4 kHz
12/24 dB Crossover Switch
Bandpass / Subsonic Filter Switch
Acoustic Phase Shift 0 - 180°
Bass Boost 0 - 18 dB @ 45 Hz
Bass Remote Controller
257 x 60 x 535/565 mm
• Heavy Aluminum Heatsink
• Absolute 1 Ohm Stability
• Balanced Inputs (Except VE1200.5)
• Double-sided Epoxy-PCB with reinforced Copper Layers
• Maxi-Fuses, molded Screwtype Terminals
• Bass Remote with Status LED
• Silver RCA Screwtype Jacks
• Top Panel with Status Illumination
white light = status normal
red light = protection moDE
FOTO :
