spia abs
  • oibaf82
    Auto posseduta: polo 9n 1.4
    spia abs
    da oibaf82 » martedì 8 maggio 2012, 18:59
    Ciao a tutti sono disperato...
    allora spia abs un giorno accesa, due no.
    pensavo bah si sarà sbagliato la macchina :017 ...
    invece ora è fissa ho fatto la diagnosi con il vag com:
    VAG-COM Version: Release 311.2-N
    Chassis Type: 9N1 - VW Polo
    Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
    Address 01 -------------------------------------------------------
    Controller: 036 906 034 DD
    Component: MARELLI 4MV 4963
    Coding: 00071
    Shop #: WSC 31414
    WVWZZZ9NZ3D158661 VWZ7Z0C6680717
    No fault code found.
    Address 03 -------------------------------------------------------
    Controller: 6Q0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0001097
    Shop #: WSC 31414
    2 Faults Found:
    01276 - ABS Hydraulic Pump (V64)
    014 - Defective - Intermittent
    012 - Electrical Fault in Circuit
    Address 08 -------------------------------------------------------
    Controller: 6Q0 820 045
    Component: Klimaanlage X0840
    1 Fault Found:
    01596 - Motor for Outside/Recirculated Air Flap (V154)
    30-00 - Open or Short to B+
    Address 09 -------------------------------------------------------
    Controller: 6Q1 937 049 C
    Component: 00 BN-SG. 1S33
    Coding: 25742
    Shop #: WSC 31414
    4 Faults Found:
    00969 - Fuse for Heated Rear Window (S41)
    37-10 - Faulty - Intermittent
    00966 - Fuse for Blinkers (S151)
    00900 - Fuse for Signal Horn (S194)
    00906 - Horn (H1)
    28-10 - Short to B+ - Intermittent
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 6Q0 920 820
    Component: KOMBI+WEGFAHRSP VDO V16
    Coding: 01141
    Shop #: WSC 00000
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: 09 GATEWAY CAN 1S33
    Coding: 00014
    Shop #: WSC 31414
    Address 44 -------------------------------------------------------
    Controller: 6Q0 423 156 R
    Component: LenkhilfeKYO V913
    Coding: 10140
    Shop #: WSC 31414
    Address 46 -------------------------------------------------------
    Controller: 6Q0 959 433 E
    Component: 4P Komfortgerát 0002
    Coding: 00067
    Shop #: WSC 31414
    End -------------------------------------------------------
    Leggendo nel forum ho controllato i fusibili nella batteria, e oggi ho smontato i sensori e puliti ma niente.
    come faccio a vedere se i sensori sono buoni?
    ma il vag me lo dovrebbe specificare se fosse il sensore?
    grazie infinitamente per il vostro aiuto
    polo 9n 2003
    1.4 benz 75cv
  • oibaf82
    Re: spia abs
    da oibaf82 » martedì 8 maggio 2012, 19:02
    dimenticavo alla diagnosi fatta avevo provato a torgliere i fusibili e mi era rimastio in memoria.
    cmq sono rimasti gli ultimi e due errori x l'abs,
    la tromba e il ricircolo.
